1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Among the things for which I wish...
To: Brian Tieman <[email protected]>
Cc: Tech-Talk <[email protected]>
Date: Mon, 10 Nov 2003 15:18:42 -0600
At 03:05 PM 11/10/2003 -0600, Brian Tieman wrote:
I'm sure someone from ASD Controls will chime in, but in case they don't...
ASD has a toolset which provides functionality something similar to 2 and 3. I've had to modify some of my code that runs on the ASD subnets to provide this functionality as well. Basically, the ioc writes a couple of files which are then parsed by a set of tools. They can find which crate has a particular PV, all the PVs in an IOC, etc...
I, too, use the "ioc% dbl > file.txt" method to generate files which can be later parsed.
This presumes that the IOC can be programmed to
do this (is this limited on a platform which can
run an IOC?) and is writing to a file system with
network access.  Suppose, for example, that the IOC
is on a Win PC which does not export the directory,
this method fails.  For the "dbl" request to work
on a system-wide basis, it needs to be a service
provided by the IOC and available without dependence
on the availability of a file system.
What about those systems where the developer has forgotten
to write this file?  We need a way to get around
the usual human engineering which can break things.
Pete
Among the things for which I wish... Pete R Jemian
Prev: Among the things for which I wish... Pete R Jemian
Next: Re: Among the things for which I wish... Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
