To find the active IOCs on your subnet you can
do something like
tpdump port 5065
and you'll see trickle in beacons. A pipeline
tcpdump -c 100 port 5065 | awk '{ print $2 }' | sort -u
gives you a sorted list of IOCs
HTH
-- Till
Pete R Jemian wrote:
Now there's the quick answer to [2].
Thanks. Maybe I'll write myself a quick C hack
that will make this happen. But, I'll have
to scan each host in the subnet for this.
At 04:43 PM 11/10/2003 -0500, you wrote:
On Mon, 10 Nov 2003, Pete R Jemian wrote:
> [2] An EPICS "ping" command or something that a sysAdmin could use to
> identify all the EPICS IOCs within a subnet. Maybe there is already
> documentation on how to do this by probing a certain port or some other
> elegant method.
Not an elegant or a fool-proof way, but 'nmap -p 5064 host' will tell you
if a host is listening on the default ca server port. (nmap available
from
www.insecure.org/nmap/ ).
> answer the question "Where is this PV?" (Maybe this, too, is already
> available from the low level C calls.
Not a way to get a list of PVs on an IOC, but ca_host_name() will tell
you
where a PV is. In medm, the "PV Info" tool makes use of this as a
convenient way to find out which IOC a PV is from.
Steve Hartman
[email protected] | 919-660-2650
Duke Free Electron Laser Laboratory
- Among the things for which I wish... Pete R Jemian
- Re: Among the things for which I wish... Pete R Jemian
Re: Among the things for which I wish... Andrew Johnson
<2003>
2025
2026
<2003>
2025
2026
