1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: syncronisation bettween records
To: tech-talk <[email protected]>
Date: Tue, 11 Nov 2003 08:28:20 +0100
Hallo Andrei,
this is a nice little finger excercise before breakfirst:
1. Detector has slow module, for example high voltage module, and ADC
digitizer module.
So I have two records (as minimum). SCAN field of ADC record is "I/O
Intr". Situation is next. Operator changes voltage setting record of High
Voltage module. ADC should wait until potential will be set. How can I do it?
You could do it in a similar way as Nr2, if you get any bit or something if the slow HV has reached its set value
2. Detector has amplifier with gain and ADC digitizer module.
Intr". Situation is next. Operator can change gain during ADC is doing
measurement (for example, ADC should take 200 samples, gain was changed on 100 samples). How can I
"freeze" gain?
|--ai--------| |ADC-Module | |------------| |--bo---------| |SCAN=IO/Intr| |pulse | |FLNK |--->-|-------------|--->----- |INP=hardware| |HIGH=.1second| | |------------| | | | |-------------| | SetGainHere | | |--calcout------------------| | | |SetGainModule | | | |---------------------------| | | |INPA |CPP<| | |CALC=A | |>-|B | |OCAL=B | |OOPT=Transition to Non-zero| |DOPT=Use OCAL | |--ao--------|
|OUT |----->-|Gain |
|OUT=hardware|
Now gain can be set whenever by the operator, but it is written to the hardware allways at the time, the ADC has finished its sample
Also I can find Record Reference Manual for Epics 3.13.7. Is there more
new manual?
Thanks, Andrei.
-- ------------------------------------------------------------------- -- [email protected] ----------- Bessy Gmbh ----------------- -- +49 30 6392 4981 ------------------ Albert Einstein Strasse 15 - -------------------------------------- 12489 Berlin ---------------
syncronisation bettween records Liyu, Andrei
Prev: this is a test. xiedong
Next: Re: syncronisation bettween records kuner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: syncronisation bettween records Liyu, Andrei
