I have a few questions concerning the periodic scan rate in EPICS and the VxWorks system clock rate. I am currently working with EPICS 3.13 on VxWorks 5.4, but would be interested if there are significant differences in 3.14. Another small addition to the other responses ... If you change the clock rate, be careful with the "delay" function of the sequencer, at least with version 1.9.2.Beta12. The argument is no longer seconds if the tick rate is not 60 Hz. It is necessary to use code of the form: %% #include <sysLib.h> float tickFactor; ss snlProgram {
state pre_init {
when () {
tickFactor = sysClkRateGet ()/60.0;
} state init
state init
when (delay (<secs> * tickFactor) {
...We use a clock rate of 250 Hz on our diffractometer stations at the material science beamline and have noticed no performance problems. Regards, David Maden [email protected] _/_/_/ _/ _/_/_/ Beamline Control Group, SLS Project _/ _/ _/ Paul Scherrer Institute _/_/ _/ _/_/ CH-5232 Villigen-PSI _/ _/ _/ Tel: +41 56 310 3616 _/_/_/ _/_/_/ _/_/_/ Fax: +41 56 310 3294
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
