1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bug in RULES.Host R3.13.*
To: TECHTALK <[email protected]>
Date: Mon, 17 Nov 2003 22:09:56 +0100
Hi Andrew,
There are 2 bugs in the .stt rule in base/config/RULES.Host.
Note RULES.Host is used when building code to run on the host, not on a vxWorks IOC. The more intriguing question is why there's a rule for .stt files in RULES.Host at all, since there was a very long gap between about Base R3.10 or earlier and R3.14 when SNL programs could only run on vxWorks.
I wondered about that a little later, too. My 2nd mail seems to be lost in space, though. The same buggy rule appears in RULES.Unix, too. As unused as in RULES.Host, I guess. I also found that RULES.Vx had been fixed meanwhile.
I stumbled over that while installing R3.13.9 when I did a grep for all hacks we had applied to R3.13.2. I was astonished that I still could find the same lines here.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
bug in RULES.Host R3.13.* Dirk Zimoch
Re: bug in RULES.Host R3.13.* Andrew Johnson
Prev: Re: bug in RULES.Host R3.13.* Andrew Johnson
Next: Re: Among the things for which I wish... Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Compiling SDDS on Linux with R3.14.4 Hammonds, John P.
