1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: sequencer SEGV
To: Jeff Hill <[email protected]>
Cc: "'Benjamin Sailer'" <[email protected]>, "'EPICS Tech-Talk'" <[email protected]>
Date: Tue, 18 Nov 2003 08:05:18 -1000 (HST)
On Tue, 18 Nov 2003, Jeff Hill wrote:
> The fact that free() fails when it is taking a mutex points somewhat towards
> some form of corruption, or if the bug is in the Linux run time support
> possibly a race condition. You might try to verify that the same problem
> occurs on a newer version of Linux. You might try also running the code on
> Solaris if it's available to see if the problem occurs there. Since this
> looks vaguely like corruption then running the code through purify, assuming
> that you have a system that supports that, might also be helpful.
Just because it may be of general interest, and Jeff doesn't mention it,
valgrind is an Open Source Linux tool that does basically the same job as
purify (at a much better price). We use it a lot. http://valgrind.kde.org/
Cheers,
Nick Rees
Head of Software and Computing Services
Joint Astronomy Centre                   Ph:         +1 (808) 961-3756
660 N. Aohoku Place                      Fax:        +1 (808) 961-6516
Hilo, HI.  96720                         Email: [email protected]
RE: sequencer SEGV Jeff Hill
Prev: RE: sequencer SEGV Jeff Hill
Next: RE: sequencer SEGV Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
