1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS to WAGO PLC using Ethernet MODBUS
To: John Maclean <[email protected]>
Cc: [email protected]
Date: Fri, 21 Nov 2003 10:10:32 -0800
John,
Can you please email me with a place where I can get this?
I think the EPICS community should settle on one of these to concentrate their efforts on. I've been doing a survey of PLCs with Ethernet field bus capability, and MODBUS over TCP/IP is the most common protocol in the market.
Eric Williams
Advanced Light Source
Lawrence Berkeley Lab
John Maclean wrote:
I have Ethernet-MODBUS support which is based on code obtained from the
Canadian Light Source. The CLS code is written to run on RTEMS and
supports Modicon PLCs.
I modified it to be OS independent, to work with 3.14.2 and to add
support for Siemens power meters.
John.
Vladis Korobov wrote:
Hi all,
I have to connect from EPICS to WAGO System PLC using MODBUS protocol (via Ethernet).
Has anybody any software for such kind of communication?
Any suggestions and advise will be appreciated,
Vladislav Korobov
MKS-2 Group, DESY
Notkestr. 85
22607 Hamburg, Germany
tel. +49 40 8998 3947
e-mail:[email protected] or
       [email protected]
EPICS to WAGO PLC using Ethernet MODBUS Vladis Korobov
Re: EPICS to WAGO PLC using Ethernet MODBUS John Maclean
Prev: EPICS training Bob Dalesio
Next: Re: Linux -> PPC cross-compile of the Motor Record Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS to WAGO PLC using Ethernet MODBUS John Maclean
Next: EPICS to WAGO PLC using Ethernet MODBUS Ivan So
