1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Tornado 2.2, cross-compiling woes
To: Epics Questions <[email protected]>
Date: Mon, 1 Dec 2003 16:52:35 +0000 (GMT)
Hi All,
I've just been experimenting with cross-compiling
EPICS 3.14.4 against Tornado 2.0.2 (vxWorks 5.4.2)
and Tornado 2.2 (vxWorks 5.5) and I wanted to share
the following result.
(Note: This is cross-compiling with the Wind River supplied
cross-compiler from Solaris->PPC, so this is separate from the
Linux->PPC posting I made a few days back).
I have the following simple database, containing a single calcout record
on a 1Hz scan:
#! Generated by VisualDCT v2.4
#! DBDSTART
#! DBD("../dbd/simple.dbd")
#! DBDEND
record(calcout, "$(user):trigger") {
  field(SCAN, "1 second")
  field(CALC, "(A=2)?1:0")
  field(OOPT, "Transition To Zero")
#! Further lines contain data used by VisualDCT
#! View(3131,2961,1.3)
#! Record("$(user):trigger",2680,2440,0,0,"$(user):trigger")
This DOES NOT work for me when compiled with T2.2
i.e. the VAL field of "$(user):trigger" stays equal to 1
no matter what value I set A equal to.
But it does work fine when compiled against T2.0.2
i.e. with the gcc-2.7.2 based compiler.
For the case which does not work (Tornado 2.2), I have:
../ccppc -v
Reading specs from /usr/software/dev/packages/vxworks/tornado2.2/ppc/host/sun4-solaris2/bin/../lib/gcc-lib/powerpc-wrs-vxworks/gcc-2.96/specs
gcc version gcc-2.96 (2.96+) 19990621 AltiVec VxWorks 5.5
65115 79101 83322 83686 84218 85823 85973 86999 87279 87638 \
88306 88708 88966 90104 90120 90296 90648 90662
(I have just patched this compiler as per Wind River's patch:
patch-tor2_2.ppc.031031 - in the hope that this would fix the problem.
I think those are SPR numbers which appear in the line above).
Any comments and I wondered how many sites are actively using
Tornado 2.2 either with a 3.13 or a 3.14 based release and if
you have noticed any subtle problems? All a bit worrying...
Cheers,
Andy
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Re: Tornado 2.2, cross-compiling woes Ernest L. Williams Jr.
Prev: Bug in sequencer v1.9.5 Redman, Russell O.
Next: Re: Tornado 2.2, cross-compiling woes Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
