1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem building 3.14.4 on solaris-sparc-gnu
To: <[email protected]>
Date: Mon, 1 Dec 2003 15:13:08 -0600
Folks,
I'm having a problem building base-3.14.4 on solaris-sparc-gnu in
libCom/misc.  The OS is SunOS 5.8. Here's the error:
> gnumake
gnumake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../..
T_A=solaris-sparc-gnu install
gnumake[1]: Entering directory
`/net/corvette/usr/local/epics/base-3.14.4/src/libCom/O.solaris-sparc-gn
u'
/usr/local/bin/g++ -c   -D_POSIX_C_SOURCE=199506L  -D_XOPEN_SOURCE=500
-DOSITHREAD_USE_DEFAULT_STACK       -DUNIX  -DSOLARIS=8
-D__EXTENSIONS__  -ansi  -O3  -Wall          -fPIC -I. -I..
-I../../../src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error
-I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/logClient
-I../../../src/libCom/macLib -I../../../src/libCom/misc
-I../../../src/libCom/osi -I../../../src/libCom/taskwd
-I../../../src/libCom/timer -I../../../src/libCom/tsDefs
-I../../../include/os/solaris -I../../../include
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp: In method
`ipAddrToAsciiTransactionPrivate::~ipAddrToAsciiTransactionPrivate()':
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308: `UINT_MAX'
undeclared (first use this function)
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308: (Each
undeclared identifier is reported only once
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308: for each
function it appears in.)
gnumake[1]: *** [ipAddrToAsciiAsynchronous.o] Error 1
gnumake[1]: Leaving directory
u'
gnumake: *** [install.solaris-sparc-gnu] Error 2
UINT_MAX is not defined.  UINT_MAX is defined in
/usr/include/sys/types.h, which is included via
ipAddrToAsciiAsynchronous.h -> osiSock.h -> os/solaris/osdSock.h ->
sys/types.h.  However, it is only defined in sys/types.h if _KERNEL is
defined.  Am I doing something wrong?
Mark Rivers
Re: Problem building 3.14.4 on solaris-sparc-gnu Andrew Johnson
RE: Problem building 3.14.4 on solaris-sparc-gnu Jeff Hill
Prev: R3.14.4 Linux IOC john sinclair
Next: Re: Problem building 3.14.4 on solaris-sparc-gnu Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
