1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tornado 2.2, cross-compiling woes
To: Richard Dabney <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Tue, 2 Dec 2003 10:32:49 +0000 (GMT)
Hi Richard,
Just to follow up on this, the original compilation
was using "-O3" (set in "configure/CONFIG.gnuCommon").
I tried changing this to "-O" and recompiling and it made no difference.
I then tried switching off optimization altogether by
setting:
CROSS_OPT=NO
in "configure/CONFIG_SITE" (this adds the "-g" flag to the compilation).
It then worked fine.
Many thanks for the suggestion!
Cheers,
Andy
On Mon, 1 Dec 2003, Richard Dabney wrote:
> If you are using compiler optimization greater than '-O' try it without it.
> On 1 Dec 2003 at 16:52, Andy Foster wrote:
> > Hi All,
> > I've just been experimenting with cross-compiling
> > EPICS 3.14.4 against Tornado 2.0.2 (vxWorks 5.4.2)
> > and Tornado 2.2 (vxWorks 5.5) and I wanted to share
> > the following result.
> > (Note: This is cross-compiling with the Wind River supplied
> > cross-compiler from Solaris->PPC, so this is separate from the
> > Linux->PPC posting I made a few days back).
> > I have the following simple database, containing a single calcout record
> > on a 1Hz scan:
> > #! Generated by VisualDCT v2.4
> > #! DBDSTART
> > #! DBD("../dbd/simple.dbd")
> > #! DBDEND
> > record(calcout, "$(user):trigger") {
> >   field(SCAN, "1 second")
> >   field(CALC, "(A=2)?1:0")
> >   field(OOPT, "Transition To Zero")
> > #! Further lines contain data used by VisualDCT
> > #! View(3131,2961,1.3)
> > #! Record("$(user):trigger",2680,2440,0,0,"$(user):trigger")
> > This DOES NOT work for me when compiled with T2.2
> > i.e. the VAL field of "$(user):trigger" stays equal to 1
> > no matter what value I set A equal to.
> > But it does work fine when compiled against T2.0.2
> > i.e. with the gcc-2.7.2 based compiler.
> > For the case which does not work (Tornado 2.2), I have:
> > .../ccppc -v
> > Reading specs from /usr/software/dev/packages/vxworks/tornado2.2/ppc/host/sun4-solaris2/bin/../lib/gcc-lib/powerpc-wrs-vxworks/gcc-2.96/specs
> > gcc version gcc-2.96 (2.96+) 19990621 AltiVec VxWorks 5.5
> > 65115 79101 83322 83686 84218 85823 85973 86999 87279 87638 \
> > 88306 88708 88966 90104 90120 90296 90648 90662
> > (I have just patched this compiler as per Wind River's patch:
> > patch-tor2_2.ppc.031031 - in the hope that this would fix the problem.
> > I think those are SPR numbers which appear in the line above).
> > Any comments and I wondered how many sites are actively using
> > Tornado 2.2 either with a 3.13 or a 3.14 based release and if
> > you have noticed any subtle problems? All a bit worrying...
> > Cheers,
> > Andy
> > Observatory Sciences Limited    Email: [email protected]
> > William James House             Tel: 44 - (0)1223 - 508259
> > Cowley Road                     Fax: 44 - (0)1223 - 508258
> > Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
> Richard Dabney
> SNS-4 LINAC Controls
> M/S H820
> TA-53, Bldg 398 Rm 104
> Los Alamos National Laboratory
> Los Alamos, NM 87545 USA
> 505-665-7860
Prev: EPICS Gateway 2_0_0_0Beta1 Steven . Banks
Next: RE: EPICS Gateway 2_0_0_0Beta1 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Tornado 2.2, cross-compiling woes Ernest L. Williams Jr.
Next: R3.14.4 Linux IOC john sinclair
