1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aiRecord, RVAL vs. VAL
To: "Mark Rivers" <[email protected]>
Cc: <[email protected]>
Date: Thu, 04 Dec 2003 17:42:35 -0500
>>> On 12/4/2003 at 16:30:38 CST, Mark Rivers wrote:
  > I agree that having the RAW field be an integer is a limitation.  For
  > example, I might want to read a voltage from a digital multimeter,
  > which returns a floating point number, but then have that number
  > converted to some other units, for example pressure, by the ai record
  > conversion routine.  As it stands I think device support would have to
  > do that conversion directly, it could not write into the RVAL field and
  > ask the record to do the conversion.
One work-around for this (which is used by devAscii, for instance) is to
scale the value read from the device up in the device support so that it
can be represented as an integer while maintaining useful precision, and
then to scale it back down in the conversion to your desired units.
- brian
RE: aiRecord, RVAL vs. VAL Mark Rivers
Prev: RE: aiRecord, RVAL vs. VAL Mark Rivers
Next: Re: aiRecord, RVAL vs. VAL Allan Honey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
