1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: "assert (this->exitWait ( DBL_MAX ))" failed
To: "'Kate Feng'" <[email protected]>, <[email protected]>
Date: Mon, 8 Dec 2003 17:20:17 -0700
Hello Kate,
> A call to "assert (this->exitWait ( DBL_MAX ))" failed in
> ..../../../src/libCom/osi/epicsThread.cpp line 60.
Quite a few bugs have been fixed in R3.14 since R3.14.0.beta.2. You should
probably upgrade to a more recent release. This means re-linking MEDM with a
newer release. In particular, I can remember that there were some problems
with proper scheduling of single-threaded CA client applications like MEDM
in R3.14 beta releases.
The function epicsThread::exitWait () is fairly low level. It is called in
several places by the CA client library. Without a stack trace it is
difficult to make any further conclusions. If you can reproduce this in a
recent version then I can send instructions on how to get a stack trace from
the debugger.
I do not know what OS was involved. There were some problems with thread
shutdown procedures on Linux and also on HPUX in early R3.14 releases.
If you see this again with a recent version we definitely want to here about
it.
> 0xa36af0 (dnsQuery): Unhandled C++ exception resulted in call to
> terminate
It sounds like this problem is easy to reproduce. Please upgrade
R3.14.0.beta.2 to a newer version of R3.14. If the problem continues please
contact me and I will assist you with debugging the problem further (with
obtaining a stack trace).
Thanks for your bug report.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Kate Feng
> Sent: Monday, December 08, 2003 4:13 PM
> To: [email protected]
> Subject: "assert (this->exitWait ( DBL_MAX ))" failed
> Hi,
> I noticed the following message on the "medm screen"
> because today users complained that they could not pop up
> the xyz.adl file from the "related display" :
> EPICS Release EPICS R3.14.0.beta.2 $R3-14-0-beta-2$ $2002/07/30
> 21:40:55$.
> Current time Tue Dec 02 2003 22:16:11.849753000.
> Please E-mail this message to the author or to [email protected]
> Calling epicsThreadSuspendSelf()
> It seems to be an intermittent problem because it is the first
> time that it occurs.  Meanwhile, I could not load any new file
> via "File" from the original medm session.  Without killing the
> original one,  I opened another medm session and I was able
> to pop up the xyz.adl via "File" or the "related display".
> Something we can get around.  It seems the IOC works fine.
> The platform :
> Medm version 3.03.
> The IOC is running R3.14.0.beta.2 VxWorks thread.
> One thing to mention is that :
> Whenever the IOC was first rebooted, I always got the following
> error message in the VxWorks thread (but never in the RTEMS
> thread. Unfortunately I did not run RTEMS on that IOC because
> I would have to borrow a mvme2306 from other projects to run) :
> terminate
> Something that was referenced in tech-talk  "dnsQuery task suspended"
> by Geoff Savage on Sep. 5, 2003.
> However, it seems that the VxWorks IOC has been running fine for six
> months.  The error message I  mentioned on the top is
> found in the medm screen.
> Regards,
> kate
"assert (this->exitWait ( DBL_MAX ))" failed Kate Feng
Prev: "assert (this->exitWait ( DBL_MAX ))" failed Kate Feng
Next: RE: Novice EPICS questions re yet another port David Kelly
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Spurious link alarms generated? J. Frederick Bartlett
