1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linking Unix Matlab-Compiled Programs against MCA
To: [email protected]
Cc: [email protected]
Date: Tue, 16 Dec 2003 17:14:08 +1100
Hi Stephanie,
I noticed your question regrading linking of MCA on linux which you posted
to tech-talk in October 2002.  Did you have any success with that?
We're currently looking a Matlab with the idea of using it as part of our
control system for the Australian Synchrotron, and I'm evaluating it on a
Red Hat linux box at the moment.  I've successfully compiled MCA (in
particular mcamain.cpp) and have a little example application up and going
which monitors one process variable. I've found it to be very unstable... I
very frequently get segmentation faults when I run the application and,
after some debugging, the problem appears to be within MCA itself.
I don't suppose you've run into anything like this in your investigations?
My next step is to try it out on Windows and see if I get the same
instability.
Steve Banks
Australian Synchrotron Project
Department of Infrastructure
Level 18, 80 Collins Street
Melbourne   VIC   3000
tel:  +613 9655 6303
fax:  +613 9655 8666
web: www.synchrotron.vic.gov.au
Re: Linking Unix Matlab-Compiled Programs against MCA Carl Lionberger
Prev: CA_UDP error message 하기만
Next: about edm1-10-0s-beta zhaozhuo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA_UDP error message Jeff Hill
Next: Re: Linking Unix Matlab-Compiled Programs against MCA Carl Lionberger
