Subject: |
EPICS R.314.4 for solaris-sparc-gnu build problem |
Kevin Tsubota <[email protected]> |
To: |
"tech-talk (E-mail)" <[email protected]> |
Date: |
Tue, 23 Dec 2003 14:23:01 -1000 |
Hi All,
I'm attempting to build EPICS R3.14.4 for solaris-sparc-gnu on a Solaris-8
host with the following versions of gcc, g++, and gmake:
kamaole{epics}187: gcc --version
2.95.2
kamaole{epics}188: g++ --version
2.95.2
kamaole{epics}189: gmake -version
GNU Make version 3.78.1, by Richard Stallman and Roland McGrath.
Built for sparc-sun-solaris2.7
Copyright (C) 1988, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99
Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
My build is failing in the gmake of the base/src/toolsComm/flex directory
because of the following error:
ld.so.1: ../../../../bin/solaris-sparc-gnu/antelope: fatal:
libstdc++.so.2.10.0: open failed: No such file or directory
gmake[4]: *** [parse.c] Killed
gmake[4]: Target `install' not remade because of errors.
When I look at the make of antelope it is all good:
gmake[3]: Entering directory
`/local/epics/r3.14.4/base/src/toolsComm/antelope'
perl ../../../configure/tools/makeMakefile.pl O.solaris-sparc-gnu
mkdir O.Common
gmake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../../..
T_A=solaris-sparc-gnu install
gmake[4]: Entering directory
`/local/epics/r3.14.4/base/src/toolsComm/antelope/O.solaris-sparc-gnu'
gmake[4]: Leaving directory
/usr/local//bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500
-DOSITHREAD_USE_DEFAULT_STACK -DUNIX -DSOLARIS=8 -D__EXTENSIONS__
-ansi -O3 -w -D_NO_PROTO -I. -I..
-I../../../../include/os/solaris -I../../../../include ../closure.c
-I../../../../include/os/solaris -I../../../../include ../error.c
-I../../../../include/os/solaris -I../../../../include ../lalr.c
-I../../../../include/os/solaris -I../../../../include ../lr0.c
-I../../../../include/os/solaris -I../../../../include ../main.c
-I../../../../include/os/solaris -I../../../../include ../mkpar.c
-I../../../../include/os/solaris -I../../../../include ../output.c
-I../../../../include/os/solaris -I../../../../include ../reader.c
-I../../../../include/os/solaris -I../../../../include ../skeleton.c
-I../../../../include/os/solaris -I../../../../include ../symtab.c
-I../../../../include/os/solaris -I../../../../include ../verbose.c
-I../../../../include/os/solaris -I../../../../include ../warshall.c
/usr/local//bin/g++ -o antelope
-L/local/epics/r3.14.4/base/lib/solaris-sparc-gnu/
-R/local/epics/r3.14.4/base/lib/solaris-sparc-gnu closure.o error.o
lalr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o
warshall.o -lCom
Installing binary ../../../../bin/solaris-sparc-gnu/antelope
gmake[3]: Leaving directory
However a ldd shows that I'm missind libstdc++.so.2.10.0:
kamaole{epics}183: ldd antelope
libCom.so.3.14 =>
/local/epics/r3.14.4/base/lib/solaris-sparc-gnu/libCom.so.3.14
libstdc++.so.2.10.0 => (file not found)
libm.so.1 => /usr/lib/libm.so.1
libc.so.1 => /usr/lib/libc.so.1
librt.so.1 => /usr/lib/librt.so.1
libpthread.so.1 => /usr/lib/libpthread.so.1
libsocket.so.1 => /usr/lib/libsocket.so.1
libnsl.so.1 => /usr/lib/libnsl.so.1
libdl.so.1 => /usr/lib/libdl.so.1
libaio.so.1 => /usr/lib/libaio.so.1
libmp.so.2 => /usr/lib/libmp.so.2
/usr/platform/SUNW,Ultra-5_10/lib/libc_psr.so.1
libthread.so.1 => /usr/lib/libthread.so.1
Other applications suffer from this problem as well, i.e. casw,
caRepeater... I could add it to my LD_LIBARY_PATH but I thought the default
config was to build things statically so the only thing that I changed in
the configuration was:
diff CONFIG.solaris-sparc-gnu.solaris-sparc-gnu
CONFIG.solaris-sparc-gnu.solaris-sparc-gnu.original
13c13
< GNU_DIR = /usr/local
> GNU_DIR = /opt/gnu
A seperate problem which I encountered was ipAddrToAsciiAsynchronous.cpp was
failing to compile due to: UNIT_MAX undefined error so I added the
following:
diff src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
src/libCom/misc/ipAddrToAsciiAsynchronous.cpp.original
29,30d28
< #include <limits.h>
What have I missed in my build?
Mahalo!
Kevin Tsubota
W.M. Keck Observatory
RE:swRecord.dbd for TDS Kiman Ha
Help with simple ioc response test app David Kelly
<2003>
2025
2026
EPICS time Mark Rivers
<2003>
2025
2026
