1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: R3.14 compatible drvSerial and drvAscii
To: [email protected]
Date: Fri, 9 Jan 2004 07:49:31 -1000 (HST)
Aloha
I have been getting various requests for EPICS R3.14 compatible versions
of drvSerial and drvAscii. I know of several sites which have done this.
If all those that have done this conversion would kindly send me a copy
then perhaps I can collate and distribute. I am unsure of the status of
the versions that have already been sent to me so, if you send me a copy,
please indicate under which platforms you are using your version and
whether or not it has been tested on other platforms.
Within the next 3-4 months I am hoping (to have time?) to convert drvAscii
to be compatible with the Eric Norum/Marty Kraimer asynDriver design
pattern. Once that is done an official release will be forthcoming.
Although, I will need help testing as I only have tests beds for
Vxworks, UNIX, and (with a little work) LINUX.
HNY,
	Allan
Prev: RE: Problem linking a Channel Access application on Windows using Visual Studio Russ Berg
Next: PV reconnect logic question Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem linking a Channel Access application on Windows using Visual Studio Steven . Banks
