1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PV reconnect logic question
To: "'Kevin Tsubota'" <[email protected]>, "'tech-talk \(E-mail\)'" <[email protected]>
Date: Mon, 12 Jan 2004 12:19:35 -0700
Kevin,
Here is your address list.
EPICS_CA_ADDR_LIST: 128.171.95.50 128.171.95.171 128.171.136.30
128.171.136.98
Does this contain the IP address of your solaris-8 IOC (or the broadcast
addres of its subnet)?
The casw program will only report a beacon anomaly when regular beacons are
disrupted and then resumed (for example when the cable is disconnected and
then reconnected).
PS: The EPICS_CAS_BEACON_ADDR_LIST variable is new in EPICS R3.14 so if your
IOC is running R3.13 both the client and the server are configured with
EPICS_CA_ADDR_LIST.
PPS: If multiple servers run on the same machine limitation in most IP
kernels prevent all of them from receiving beacons addressed to broadcast
addresses.
Jeff
> -----Original Message-----
> From: Kevin Tsubota [mailto:[email protected]]
> Sent: Monday, January 12, 2004 12:04 PM
> To: 'Jeff Hill'; 'tech-talk (E-mail)'
> Hi Jeff,
> Here are my Sol-8 IOC environment variables:
> epics> coreRelease
> ###  EPICS IOC CORE built on Jan  9 2003
> ###  EPICS R3.14.1 $R3-14-1$ $2002/12/12 15:56:59$
> epics>
> epics> epicsPrtEnvParams
> EPICS_AR_PORT: 7002
> EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
> EPICS_CAS_BEACON_ADDR_LIST is undefined
> EPICS_CAS_BEACON_PERIOD is undefined
> EPICS_CAS_BEACON_PORT is undefined
> EPICS_CAS_IGNORE_ADDR_LIST is undefined
> EPICS_CAS_INTF_ADDR_LIST is undefined
> EPICS_CAS_SERVER_PORT is undefined
> 128.171.136.98
> EPICS_CA_AUTO_ADDR_LIST: YES
> EPICS_CA_BEACON_PERIOD: 15.0
> EPICS_CA_CONN_TMO: 30.0
> EPICS_CA_MAX_ARRAY_BYTES: 16384
> EPICS_CA_REPEATER_PORT: 5065
> EPICS_CA_SERVER_PORT: 5064
> EPICS_CMD_PROTO_PORT is undefined
> EPICS_IOC_LOG_FILE_COMMAND is undefined
> EPICS_IOC_LOG_FILE_LIMIT: 1000000
> EPICS_IOC_LOG_FILE_NAME is undefined
> EPICS_IOC_LOG_INET: 128.171.97.52
> EPICS_IOC_LOG_PORT: 7004
> EPICS_TIMEZONE: CUS::360:040602:102602
> EPICS_TS_NTP_INET is undefined
> epics>
> According to the R3.14 CA Ref Man, section Server Beacons:
> If EPICS_CAS_BEACON_ADDR_LIST is not defined,
> EPICS_CA_ADDR_LIST is defined, and
> EPICS_CAS_INTF_ADDR_LIST is not defined,
> then the conents of EPICS_CA_ADDR_LIST will be used to
> augment the list.
> It looks like me setup meets this criteria yet I don't see the server
> beason.
> Is it because my EPICS_CAS_BEACON_PERIOD is not defined and
> not defaulting
> to the default 15s?
> I am running casw but the only time I saw a beacon anomoly whas when I
> started
> up caSnooper.  I'll explicitly set my EPICS_CAS_BEACON_PERIOD but was
> wondering
> why I get no beacon anomolies.
> From: Jeff Hill [mailto:[email protected]]
> Sent: Monday, January 12, 2004 5:41 AM
> To: Kevin Tsubota; 'tech-talk (E-mail)'
> Kevin,
> Your Solaris-8 IOC (acting as a client) probably does not see
> the server's
> beacons because they are addressed to subnet on which your
> client IOC is not
> listening. The EPICS R3.14 CA reference manual explains this
> situation in
> more detail than in past versions of the manual. See the
> section entitled
> "Dynamic Changes in the CA Client Library Search Interval".
> It may be that a simple solution will be to expand the server's beacon
> address list so that beacons are broadcasted also on your
> Solaris-8 IOC's
> subnet. Alternatively, you could install a CA gateway
> providing transparent
> connectivity for remote clients.
> Jeff
> > Sent: Friday, January 09, 2004 6:02 PM
> > To: tech-talk (E-mail)
> > Subject: PV reconnect logic question
> > Hi,
> > I have EPICS R3.14.1 IOC running on Solaris-8 and it
> connects to EPICS
> > R3.13.0b12 PVs running
> > under VxWorks.  As an interim safety measure I disconnect the routes
> > between
> > the two IOCs at
> > night and reconnect them during the day.
> > However when I reestablish the routes, my R3.14 IOC PV
> never reconnects
> > to
> > the VxWorks PVs.
> > It stays in STAT=LINK, SEVR=INVALID state.  THe R3.14 PV is
> using a CPP
> > input link to the
> > VxWOrks PV.  When I restart my R31.4 IOC it connects up right away.
> > Why doesn't the R3.14 PV reconnect automatically?
> > Is there a way to force the R3.14 PV to reconnect without having to
> > restart
> > it?
> > Mahalo!
> > Kevin Tsubota
> > W.M. Keck Observatory
RE: PV reconnect logic question Kevin Tsubota
Prev: RE: PV reconnect logic question Kevin Tsubota
Next: Re: compile error of EPICS 3.14.4 under windows Steven . Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Running epics in background in linux Rok Sabjan
