1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Epics server stop
To: "'Liyu, Andrei'" <[email protected]>, <[email protected]>
Date: Thu, 15 Jan 2004 16:19:37 -0700
> but some threads exit with 0 and some with 1. Is it Ok?
The function _beginthreadex() is used by epicsThreadCreate() to make a new
thread on windows. The new thread jumps into an epics internal wrapper
function that calls the user's function. It should always be returning one.
So I dont know why visual C++ is reporting different return codes. This
might be a feature of an internal wrapper employed by _beginthreadex().
Jeff
> -----Original Message-----
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Thursday, January 15, 2004 9:48 AM
> To: [email protected]
> Subject: Epics server stop
> Hi,
> I try to use Epics 3.14.4 under Windows for win32-x86.
> I work with Epics from Visual C++ environment :)
> I see how much threads Epics uses but some threads exit with
> 0 and some
> with 1.
> Is it Ok?
> The thread 0xA04 has exited with code 1 (0x1).
> The thread 0xC48 has exited with code 1 (0x1).
> The thread 0x1B4 has exited with code 1 (0x1).
> The thread 0xFB4 has exited with code 1 (0x1).
> The thread 0xB88 has exited with code 1 (0x1).
> The thread 0xCD8 has exited with code 1 (0x1).
> The thread 0xB40 has exited with code 1 (0x1).
> The thread 0x888 has exited with code 1 (0x1).
> The thread 0xF24 has exited with code 1 (0x1).
> The thread 0xE74 has exited with code 1 (0x1).
> The thread 0x840 has exited with code 1 (0x1).
> The thread 0xA8C has exited with code 1 (0x1).
> The thread 0x960 has exited with code 1 (0x1).
> The thread 0xFC4 has exited with code 1 (0x1).
> The thread 0xB24 has exited with code 1 (0x1).
> The thread 0x6D4 has exited with code 1 (0x1).
> The thread 0xE7C has exited with code 1 (0x1).
> The thread 0x818 has exited with code 1 (0x1).
> The thread 0x97C has exited with code 1 (0x1).
> The thread 0xE88 has exited with code 1 (0x1).
> The thread 0x920 has exited with code 1 (0x1).
> The thread 0x8F4 has exited with code 1 (0x1).
> The thread 0xC04 has exited with code 1 (0x1).
> The thread 0xF50 has exited with code 1 (0x1).
> The thread 0xB30 has exited with code 1 (0x1).
> The thread 0xD20 has exited with code 1 (0x1).
> The thread 0xA48 has exited with code 0 (0x0).
> The thread 0xBFC has exited with code 0 (0x0).
> The thread 0xFC8 has exited with code 0 (0x0).
> The thread 0x3A0 has exited with code 0 (0x0).
> The thread 0xE28 has exited with code 0 (0x0).
> The thread 0xF44 has exited with code 0 (0x0).
> The thread 0x8E0 has exited with code 0 (0x0).
> The thread 0x74 has exited with code 0 (0x0).
> The thread 0xBF8 has exited with code 0 (0x0).
> The thread 0x958 has exited with code 0 (0x0).
> The thread 0x13C has exited with code 0 (0x0).
> The thread 0x900 has exited with code 0 (0x0).
> The thread 0x3B0 has exited with code 0 (0x0).
> The thread 0xFEC has exited with code 0 (0x0).
> The thread 0x5AC has exited with code 0 (0x0).
> The thread 0xB70 has exited with code 0 (0x0).
> The thread 0xCD4 has exited with code 0 (0x0).
> The thread 0xBF0 has exited with code 0 (0x0).
> The thread 0xA20 has exited with code 0 (0x0).
> The thread 0xE20 has exited with code 0 (0x0).
> The thread 0xB68 has exited with code 0 (0x0).
> The thread 0x91C has exited with code 0 (0x0).
> The thread 0x980 has exited with code 0 (0x0).
> Thank,
> Andrei.
Epics server stop Liyu, Andrei
Prev: Re: ? monitor and waveform record Steven Hartman
Next: RE: Epics server stop Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Epics server stop Liyu, Andrei
