1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Access control and "odd" user names
To: [email protected]
Date: Mon, 26 Jan 2004 15:03:45 -0500
Looking at the YACC code for parsing access control files, I see that "name lists" consist of comma separated "names":
uag_user_list:	uag_user_list ',' uag_user_list_name
	|	uag_user_list_name
uag_user_list_name: tokenNAME
	Looking at the LEX code, I see that names consist of the
following characters:
name [a-zA-Z0-9_\-:\.\[\]<>;]+
That works fine for the user name I was assigned on my LINUX box, but it does not work well for the user name I was assigned on my Windows box, which has an embedded space (' ').
	The expedient solution is to change the space to another
semi-invisible character on my Windows box. However, I was wondering
whether others have run into this, and/or perceive this as an issue
worth trying to address, or whether there are additional problem
associated with supporting a space character in access control.
-- Larry
P.S. I *suspect* that there are no issues with supporting embedded
spaces in user names (other than readability issues), since the user
name string is treated as a string once it has been read in, and that
it is no less readable than other strings with embedded spaces, such
as scan rates of "1 second".
Prev: open post at DESY in the cryogenic control group Matthias Clausen
Next: Definitions of RELEASE_ variables Chris Mayer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
