Peter,
I have compiled and am running the ChannelArchiver on the same
version of Linux that you are running. However, it is a later
version of ChannelArchiver (the final for EPICS 3.13.x) which
was rewritten to eliminate the code that is causing your problem.
I downloaded channelarchiver-1.10.2.src.zip from http://ics-web1.sns.ornl.gov/~kasemir/archiver/index.html
<http://ics-web1.sns.ornl.gov/%7Ekasemir/archiver/index.html>
Hoping this helps,
Susanna
Peter Groszkowski wrote:
> Hello:
> Let me quickly outline my system configuration:
> Epics version: 3.13.9
> ChannelArchiver version: 1.9.1
> OS: RedHat9 ( kernel 2.4.20)
> gcc version from running 'gcc -v':
> Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/3.2.2/specs
> Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
> --infodir=/usr/share/info --enable-shared --enable-threads=posix
> --disable-checking --with-system-zlib --enable-__cxa_atexit
> --host=i386-redhat-linux
> Thread model: posix
> gcc version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)
> I was wondering whether anyone has been using the ChannelArchiver under
> RedHat9. I am having a few minor compilation issues which I believe may
> be related to my version of gcc.
> Essentially the problem is due to a line (in two different files):
> _file.unsetf (std::ios::binary);
> where _file is an object of type std::ifstream. The error I get is:
> In file included from ../ASCIIParser.cc:6:
> ..../ASCIIParser.cpp: In member function `bool ASCIIParser::open(const
> stdString&)':
> ..../ASCIIParser.cpp:25: no matching function for call to `
> std::basic_ifstream<char, std::char_traits<char> >::unsetf(const
> std::_Ios_Openmode&)'
> /usr/include/c++/3.2.2/bits/ios_base.h:361: candidates are: void
> std::ios_base::unsetf(std::_Ios_Fmtflags)
> gmake[1]: *** [ASCIIParser.o] Error 1
> gmake[1]: Leaving directory
> `/usr/local/epics_versions/epics3.13.9GEM8.5/extensions/src/Tools/O.Linux'
> gmake: *** [install.Linux] Error 2
Susanna Jacobson MS 10-110
[email protected] Lawrence Berkeley National Laboratory
VOICE: (510) 486-7801 1 Cyclotron Road
FAX: (510) 486-7374 Berkeley, CA 94720
- ChannelArchiver and gcc 3.2.2 on linux Peter Groszkowski
Unix Pretty-print for .st (SNL, or Sequencer programs) Chestnut, Ronald P.
seq 2.0.7 now available Laznovsky, Michael
<2004>
2025
2026
Re: ChannelArchiver and gcc 3.2.2 on linux Kay Kasemir
edd/dm and Red Hat Linux Nick Rees
<2004>
2025
2026
