Benchmarks are misleading and often unreliable. However they are also
interesting, so I have done some comparative tests on epics performance.
I have a database of calc records processing at 10Hz, and measure the CPU
load for different IOC types. Here are some of the results: The value of ES
is the comparative performance normalized to one of our standard VxWorks
systems.
Machine OS MEM(MB) CPU Speed L2cache Rec/sec %CPU ES
mvme2306 vxWorks 32 PPC604 10000 10 1.000
PC RH73 131 MobP4 1.7GHz 100000 36 2.778
PC RH62 ? PIII 1.0GHz 256K 100000 74 1.351
PC RH62 128 PII 233MHz 10000 27 0.370
PC RH73 256 PIII 700MHz 50000 37 1.350
PC RH73 223? Celeron 2.4GHz 128K 50000 18 2.778
PC RH73 256 P4 2.4GHz 512K 50000 9 5.556
I suspect that the much better performance of the Pentium 4 system compared
to the Celeron is due to having more level 2 cache rather than just the CPU.
As you would expect, the results for a particular machine do not change
(much) if you vary the number of records.
Steve
-----Original Message-----
From: Tatiana V. Salikova [mailto:[email protected]]
Sent: Sonntag, 15. Februar 2004 17:00
To: [email protected]
Subject: How is it that IOC process only 11000 records per second at AMD
Duron 850MHz?
Hello,
How is it that IOC process only 11000 records per second at AMD Duron
850MHz?
R3.14.5 works at RedHat 8. Database consist of 40000 ai records,
synchronous devAiSoft servers all records, routine increments value
pai->val. if records is scanned with o.1sec interval, then some PVs does
not changes
"if a device causes delays of greater than 100usec
then asyn device support is appropriate." from IOC guide ch.12
Is restriction determinate RTC effect? x86 has worked with 100Hz, 68K has
60Hz?
"68040 IOC can process more then 6000 records per sec" IOC guid 3.2 basic
attributes.
RTC_x86/RTC_68K=1.7 mavPV_x86/maxPV_6=11000/6000=1.8
thank you
Best Regards,
Tatiana
Budker Institute of Nuclear Physics
prospekt Lavrentev 11
630090, Novosibirsk, RUSSIA
fax +7 3832 342163
phone +7 3832 394977
e-mail: [email protected]
How is it that IOC process only 11000 records per second at AMD Duron 850MHz? Tatiana V. Salikova
RE: CA question Jeff Hill
<2004>
2025
2026
drvAscii ipacAddCarrier routine John Faucett
<2004>
2025
2026
