I have tried to load an ao-record with a PV-Link. If this PV unknown, the
ioc-shell crashes at init-time.
The first time I used Base3.14.2, now I'm using Base-3.14.5.
Both have produced the same errors.
I have excluded all unimportant files.
(Linux Kernel 2.4.18)
Thanks Frank.
An example that works:
record(ao,"hi:de_pid") {
field(DESC,"analog output")
field(DTYP,"Soft Channel")
field(DOL,"1")
field(PREC,"3")
field(OMSL,"closed_loop")
record(ao,"ho:e") {
field(DOL,"hi:de_pid.VAL")
field(PREC,"3")
Example does'nt work:
record(ao,"ho:e") {
field(PREC,"3")
The shell window shows below:
hoeft@captain:/home/epics_usr/tstdb/iocBoot/ioctpsd$ ../../bin/linux-x86/tpsd
st.cmd
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"ioctpsd")
epicsEnvSet(TOP,"/home/epics_usr/tstdb")
epicsEnvSet(EPICS_BASE,"/opt/base-3.14.5")
cd /home/epics_usr/tstdb
dbLoadDatabase("dbd/tpsd.dbd")
tpsd_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("db/dbExample1.db","user=epics_usrHost")
dbLoadRecords("db/dbExample2.db","user=epics_usrHost,no=1,scan=1 second")
dbLoadRecords("db/dbExample2.db","user=epics_usrHost,no=2,scan=2 second")
dbLoadRecords("db/dbExample2.db","user=epics_usrHost,no=3,scan=5 second")
dbLoadRecords("db/dbSubExample.db","user=epics_usrHost")
dbLoadRecords("db/pid_sub.db")
cd /home/epics_usr/tstdb/iocBoot/ioctpsd
iocInit()
Starting iocInit
### EPICS IOC CORE built on Feb 24 2004
### EPICS R3.14.5 $R3-14-5$ $2004/02/04 20:45:33$
Frank Hoeft Tel. : ++49-30-6392-4679
BESSY FAX : ++49-30-6392-4980
Albert Einstein Straße 15 email: [email protected]
12489 Berlin
Germany
Re: Problem of NORD field in waveform (R3.14.4) Marty Kraimer
print from interrupt D. Peter Siddons
<2004>
2025
2026
<2004>
2025
2026
