Thanks to all who responded. I should have made it clear that I was
talking about an RTEMS app., which only has
epicsInterruptContextMessage(), which can only print a string, no
formatting. Eric Norum suggested using snprintf() to fill a buffer and
pass that to epicsInterruptContextMessage(). That seems to work fine. I
had the impression before that calling any of the xprintf() commands
from within interrupt context wasn't allowed, but apparently the string
variants are OK.
Pete.
Mark Rivers wrote:
Hi Pete,
Is there a way in EPICS to print a numeric parameter from
within an ISR, similar to epicsInterruptContextMessage(), but capable
of
printing the value of a variable (integers, anyway)? Or must I write a
routine to do it? It would be a useful debugging aid.
This may be a dumb question, but can you call sscanf at interrupt level?
If so you can convert your number to a string and then just use
D. Peter Siddons
Bldg. 725D, NSLS
Brookhaven National Laboratory
Upton, NY 11976
USA.
Email: [email protected]
- Re: print from interrupt Eric Norum
print from interrupt D. Peter Siddons
Re: gtr1-2 for SIS3301. Andrew Johnson
<2004>
2025
2026
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
