1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problems building SNC/SEQ 2.0.8 for win32-x86
To: [email protected]
Date: Tue, 02 Mar 2004 15:28:25 -0600
I've noticed a couple of small problems building SNC/SEQ 2.0.8 for win32-x86 (MSVC 6.0, epics base 3.14.5, gnumake 3.80) using the dos command line environment, which I believe is supposed to be supported:
- generation of seqVersion.c uses a shell script.
- generation of sncVersion.c uses a perl script, but the form of command used to get the date/time, "date", is interactive and doesn't work. using "date /T" works for me.
If there's some configuration problem on my part I'd appreciate any suggestions as to corrections.
dale brewe
Dale L. Brewe PNC-CAT/U. of Washington
ph: 630 252 0582 fax: 630 252 0580
Mail:
Argonne National Laboratory
Bldg 435E sector 20
9700 S. Cass Ave.
Argonne, IL 60439
Prev: compile error mpf2-4 on win32-x86 Dale L. Brewe
Next: RE: Help for EDM XYGraph widget Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
