1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EtherNet/IP for AB SLC5/05 PLC.
To: Kiman Ha <[email protected]>
Cc: [email protected]
Date: Mon, 8 Mar 2004 09:13:11 -0700
On 2004.03.08 02:24, Kiman Ha wrote:
> Hello! Kay and Stephanie,
> Last Feb, I asked about AB SLC5/05 processor for Ethernet TCP/IP EPICS
> driver and support.
> The AB Comapny people said SLS5/05 PLC processor support EtherNet/IP.
Yes, it might support the common portion of the EtherNet/IP
protocol, the part that's documented at www.odva.org.
That will allow you to read the serial number of your SLC5/05's
ethernet interface.
In addition, you need the CIP service codes that are specific
to your PLC, the ones that allow you to read/write tags
or files or whatever the data of interest is called on the
respective architecture.
> I known your alread developed EtherNet/IP drivers and support for SNS
> project.
That EtherNet/IP driver package uses the CIP codes for the
AB ControlLogix 5000 series as described in
AB Publication 1756-RM005A-EN-E.
The latter publication also lists SCL commands,
but they are very different from the CIP service codes
for the ControlLogix series.
Control Logix uses CIP service codes
0x4C : read data
0x4D : write data
0x0A : multi request
and all those adress string tags on the Logix5000.
As far as I know, the SCL5 doesn't have string tags
but uses file/element/subelement addressing.
So I'm afraid those AB people who talked to you can
recite "EtherIP" from some SLC5 brochure but don't
really understand the protocol.
This means that the ether-ip driver for the ControlLogix 5000 won't
talk to the SLC5, and making it talk to the SLC5 would be a major deal,
close to starting from scratch.
Re: EtherNet/IP for AB SLC5/05 PLC. john sinclair
EtherNet/IP for AB SLC5/05 PLC. Kiman Ha
Prev: [Fwd: LabView/EPICS] Ned Arnold
Next: Re: [Fwd: LabView/EPICS] Brian Tieman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EtherNet/IP for AB SLC5/05 PLC. Kiman Ha
Next: Re: EtherNet/IP for AB SLC5/05 PLC. john sinclair
