1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tornado 2.2.1
To: "Ronald L. Sluiter" <[email protected]>
Cc: john sinclair <[email protected]>, tech talk <[email protected]>
Date: Wed, 17 Mar 2004 14:11:35 -0600
Ronald L. Sluiter wrote:
Have you removed -nostdinc from the EPICS configuration file <base>/config/CONFIG.Vx
as documented below?
It appears that you have to remove more than just the -nostdinc option - there are several other gcc flags which used to be required but are no longer needed, and they might be causing the problems. I have Tornado 2.2 failing to build the bitbus driver, probably related to the -traditional flag which everything in src/drv/old uses.
At APS we're not likely to need to use this combination of versions, but if anyone works out what the required changes are to the compiler options [assuming that's really the cause of the problem] please be sure to let us (Janet <[email protected]>) know as we're going to be coming out with a release 3.13.10 within about a month - mostly Channel Access fixes.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
Re: Tornado 2.2.1 Ronald L. Sluiter
Tornado 2.2.1 john sinclair
Prev: Re: Tornado 2.2.1 Ronald L. Sluiter
Next: Re: Tornado 2.2.1 Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
