So this looks OK? Is there something else I should check? Clearly something is going on on the network there that is causing these problems. There are two different kinds of network buffers in vxWorks that can run out. In Tornado 2.x mbufShow() is a synonym for netStackDataPoolShow() which shows the buffers used by the IP stack for data packets. There is another command netStackSysPoolShow() which is shows the state of the system buffer pool - these buffers are used for the ARP cache, routing tables and other system storage associated with the network. However in the above case you might find there's nothing wrong with these buffers either. I'm not quite sure what causes ENOBUFS errors when sending CA beacons; I have seen similar errors on IOCs here that have never run out of DataPool or SysPool buffers, and I don't yet know what they're complaining about (any ideas Jeff?). They do appear to be benign though, if my memory is correct - the loss of a beacon can cause some unnecessary CA searches to occur, but nothing should break. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
