1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Buffer problems
Cc: Andrew Johnson <[email protected]>, [email protected], [email protected], [email protected], smtp lanzirotti <[email protected]>
Date: Fri, 26 Mar 2004 18:53:31 -0500
Hi Mark,
Please be sure to check if you have a CA Server misconfiguration
somewhere.
You can check this with Jeff's casw program.
If a CA server has for example "EPICS_CA_AUTO_ADDR_LIST=NI", it will
chatter indefinitely on your network.  All CA clients will search like
crazy since they believe someone has joined the party.
Next if the routers are setup to forward broadcasts this will cause
havoc.  Maybe the CA server library should guard against this, somehow?
What level of broadcasts do you see on your network?
Ernest
On Fri, 2004-03-26 at 14:22 -0600, Mark Rivers wrote:
> Dear Andrew,
> This problem is becoming critical.  Every vxWorks/PowerPC IOC at the
> NSLS at Brookhaven is crashing within minutes if it is connected to the
> NSLS network.  The only way the beamlines can run is to disconnect their
> switches from the NSLS network.  Tim Mooney told me yesterday that
> several CATs are now seeing this problem here as well.  It is not known
> if the network activity that is crashing the IOCs is a malicious or not.
> Finding the source of the packets at the NSLS is being worked on, but
> the real solution is to see if there is a fix for the network software
> on vxWorks to make it immune to this problem.  Can you see if Wind River
> has a patch that fixes this?
> Thanks,
> Mark
RE: Buffer problems Mark Rivers
Prev: Re: Buffer problems Graham Waters
Next: RE: Buffer problems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
