Hello,
There are know issues with strip tool and EPICS R3.14.5 which don't exist
with EPICS R3.14.4 (see bug reports in Mantis). However, it initially
appears that the symptoms of your problem (failure to connect) do not match
well with the known issues documented in Mantis, and you mention that other
client side tools (ca_test etc) also do not connect properly. Please see the
trouble shooting section in a recent CA reference manual. After following
those steps, if you are still having troubles then feel free to send email
and I will see if I can make further suggestions.
Jeff
> -----Original Message-----
> From: JaSeong Ju [mailto:[email protected]]
> Sent: Friday, April 09, 2004 12:24 AM
> To: [email protected]
> Subject: Problem starting StripTool
> Greetings,
> I installed the ioc example as described in manual and succeded
> in starting it as shown:
> $../../bin/linux-x86/myexample st.cmd
> epics> dbl
> juHost:aiExample
> juHost:aiExample1
> juHost:aiExample2
> juHost:aiExample3
> juHost:calcExample
> juHost:calcExample1
> juHost:calcExample2
> juHost:calcExample3
> juHost:compressExample
> juHost:subExample
> juHost:xxxExample
> epics>
> What I'm trying to do now is to start Striptool. After Striptool
> starts, I put the PV name into the upper window and connect. Then
> open the graph window. The plot is empty.
> It looks like PV name is not connected to StripTool.
> When I issue command
> $caget juHost:aiExample
> Channel connect timed out: 'juHost:aiExample' not found.
> $ca_test juHost:aiExample
> Not Found juHost:aiExample
> How do I fix this?
> Thanks.
- Problem starting StripTool JaSeong Ju
RE: Bidirectional device support Purcell, J. David
RE: Bidirectional device support Tang, Johnny Y.
<2004>
2025
2026
RE: Bidirectional device support Thompson, David H.
<2004>
2025
2026
