1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bidirectional device support
To: "Liyu, Andrei" <[email protected]>, "Purcell, J. David" <[email protected]>, "Lionberger, Carl A." <[email protected]>, "Thompson, David H." <[email protected]>, "Andrew Johnson" <[email protected]>, "tech-talk" <[email protected]>
Date: Mon, 12 Apr 2004 14:01:20 -0600
At the CLS, where LOCAL/REMOTE is available it is a physical switch like
an HOA.  If someone at the device switches it to local, that's where it
stays until it is switched to remote.  I deal with the Siemens PLCs and
we have a method of syncing the IOC data buffers with those on the PLC
before it is allowed to update after a switch from LOCAL to REMOTE.
As far as a READ/WRITE variable is concerned, from my limited
experience, it appears that one would be useful for checking/setting
bytes of PLC memory.
Rob
> -----Original Message-----
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Monday, April 12, 2004 1:23 PM
> To: Purcell, J. David; Lionberger, Carl A.; Thompson, David
> H.; Andrew Johnson; tech-talk
> At first, program is reflection of detectors/subsystem,
> modules (unfortunately, Epics hasn't it). When people develop
> REMOTE/LOCAL switch this question up all time. Who is master
> - local or remote? Some years ago we (INR-accelerator
> division-beam lab) came to two-states
> (LOCAL-Middle) switcher and three-positions
> (LOCAL-Middle-REMOTE) detector state (operator can see by LEDs).
> So
> Remote control
> - has full control in REMOTE position
> - can move state from Middle position to REMOTE position
> - can just read data in LOCAL position
> Local control
> - has full control in LOCAL position
> - can move state from Middle position to LOCAL position
> - can just see data in REMOTE position
> At second, bi-direction data is not need usually. Operator in
> LOCAL (rack place) and REMOTE (from computer) sets new value
> and than sees it. This is two operations, two values ...
> Andrei.
> From: Purcell, J. David [mailto:[email protected]]
> Sent: Monday, April 12, 2004 12:17 PM
> To: Lionberger, Carl A.; Thompson, David H.; Andrew Johnson; tech-talk
> To clarify the LabView implementation as SNS, although
> deployed via shared memory, control of the remote/local
> switch for the LabView devices is set up as Carl points out.
> The switch is implemented in LabView and only read with
> EPICS.  Control can not be taken away from the poor guy
> testing (probably me).  So operators can not take control of
> a diagnostic until it is returned to a remote controlled
> state. However, work done locally must be reflected on
> operator screens and although Dave Thompson does not have
> control over how we operate, he has certainly helped us with
> shared memory and the "reflection" of settings allowing us to
> operate.  I should also say that, obviously, all work
> done locally is coordinated with operations.
> Dave
> From: Carl Lionberger [mailto:[email protected]]
> Sent: Monday, April 12, 2004 10:57 AM
> To: Thompson, David H.; Andrew Johnson; tech-talk
> I think the desire for bidirectional records reflects some personal
> preference; some people think there is some kind of elegance
> about it. I
> agree with Andrew that it is not realistic.  I think it can
> be easily avoided
> in all cases, as I outline below.
> >===== Original Message From "Thompson, David H."
> <[email protected]>
> >===== If you are trying to do I/O on the same point you are
> right.  You
> >can't really turn most hardware around like that anyway.
> There are two
> >or three cases that I think we (at SNS) need to be able to do
> >bi-directional I/O; when talking to a smart device and you
> want to do
> >bumpless transfer of control between local and remote,
> This sounds equivalent to having a remote/local switch on the
> device; the
> switch is implemented in labview.  I thought it was SNS
> policy to not have
> EPICS control remote/local switches.  These should be
> controlled at the device
> (locally).  EPICS reads them.  Some poor guy locally testing
> the hardware
> should not have control taken away from the control room.
> Its not safe.
> [>]when you have a
> >device that can set one state and depends on Epics to set the other
> >state,
> For this you have an output record that sets it and a
> readback record that
> reads it.  I find the least confusing way to do this is to
> have the output
> record be momentary, ie, a bo with a HIGH of about 1 so that
> when you push the
> button it sets the state (which is read out) and returns to standby.
> [>]and when you have more than one PV pointing at the same hardware
> >address in the OUT field.
> In this case, last gets it. This just says you monitor the
> val field. The
> difference from the normal case is that all device supports
> which write to the
> same hardware must post monitors when any of them controls
> it.  Its not really
> bidirectional control.
> Carl
> Carl Lionberger
> SNS Controls Group
> (865) 574-7636
Prev: RE: Bidirectional device support Liyu, Andrei
Next: RE: Bidirectional device support Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Bidirectional device support Luedeke Andreas
Next: RE: Bidirectional device support Liyu, Andrei
