I'm trying to initialise an analog output record
by putting a constant in the DOL field (see below).
But the VAL field gets set to zero rather than 100.
The record does process and outputs this zero.
I can work around this by Initialising from another record
using clsed loop mode but it does seem to be a bit of a cludge
(see commented out lines).
What am I doing wrong?
record(ao, "$(device):SETSIZE") {
field(DESC, "Pump Size")
field(DTYP, "ornlSerial")
field(OUT, "@digitel mpc size p=1 u=$(port) m=$(unit) p1=$(pump)")
field(PINI, "YES")
field(DOL, "100.0")
# field(DOL, "$(device):INITSIZE")
# field(OMSL, "closed_loop")
field(EGU, "l/s")
field(DRVL, "0.0")
field(DRVH, "1200.0")
field(LOPR, "0.0")
field(HOPR, "1200.0")
field(PREC, "0")
record(ai, "$(device):INITSIZE") {
field(VAL, "200.0")
Pete
mailto:[email protected]
phone:+44 (0)1925 603974
fax: +44 (0)1925 603124
CLRC
Daresbury Laboratory
Keckwick Lane
Warrington
WA4 4AD
UK
- RE: Initialising an ao record from a constant DOL Kim, Kukhee
Base R3.13.10 now available Andrew Johnson
VDCT build 1249 available John Maclean
<2004>
2025
2026
<2004>
2025
2026
