Kiman,
I do not have trouble
compiling on WIN32. There have been recent changes in that part of the
code. First try doing a make clean, then make. If that doesn't work,
get the latest version of the Gateway (Gateway2_0_0_0beta10). If that
doesn't work, try to determine why the compiler thinks the linkage is
different.
-Ken
Hello all.
I tried to
replacement old config and configre directoris to last vertions. The
previous my compile problem was config and configure files used old
versions.
And I compile gateway2.0 with new configure files under
Windows but i found compile errors. I will be testing to under Linux and
Solaris when i return to PLS.
HOST : Win2K and Visual C
6.0 base 3.14.5
---- error
--- C:\epics\extensions\src\gateway>make make -C O.win32-x86 -f
../Makefile.Host T_A=win32-x86 BUILD_TYPE=Host install make[1]: Entering
directory `/cygdrive/c/epics/extensions/src/gateway/O.win32-x86' cl /GX /GR
/nologo /D__STDC__=0 /Ox /W3 -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS
-DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIO NS /DWIN32 /D_WINDOWS /MD -I. -I..
-I../../../include/os/WIN32 -I../../../include
-Ic://epics/base-3.14.5/include/ os/WIN32 -Ic://epics/base-3.14.5/include
-c /Tp ../gateAsCa.cc gateAsCa.cc ../gateAsCa.cc(43) : error C2375:
'connectCB' : redefinition; different linkage ../gateAsCa.cc(38) : see
declaration of 'connectCB' ../gateAsCa.cc(66) : error C2375: 'eventCB' :
redefinition; different linkage ../gateAsCa.cc(39) : see declaration of
'eventCB' make[1]: *** [gateAsCa.obj] Error 2 make[1]: Leaving directory
`/cygdrive/c/epics/extensions/src/gateway/O.win32-x86' make: ***
[install.win32-x86] Error
2
Kiman, PLS
Control Group.
To: "Tech-Talk" Subject:
Re: gateway2_0_0_0Beta8 compile error. From: "Kenneth Evans, Jr."
Date: Wed, 28 Apr 2004 09:39:18 -0500
Kiman,
Based on your output, the base you are using is
apparently 3.13 (solarisGnu), and you are getting 3.13.9 headers. Gateway
2.0 requires 3.14.5 or later.
First, set COMPAT_TOOLS_313=YES in
base/configure/CONFIG_SITE and then do a make in base/config/tools to
install the necessary Perl scripts. This is necessary starting with
3.14.5.
Second, set EPICS_BASE to your 3.14.5 base
in extensions/config/RELEASE.
The Gateway should build properly on
solaris-sparc, linux-x86, and win32-x86. I do these three platforms
regularly.
-Ken
- RE: RE: gateway2_0_0_0Beta8 compile error hkm
VxWorks 6.0 and Enterprise licensing scheme Andrew Johnson
<2004>
2025
2026
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
