1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: building R3.13 extensions with R3.14.5
To: [email protected]
Date: Fri, 14 May 2004 13:54:30 -0500
As the subject says I am attempting to build R3.13 extensions with R3.14.5. I am following the instructions at http://www.aps.anl.gov/epics/modules/base/R3-14/5-docs/BuildingR3.13ExtensionsWithR3.14.html with no success. Here are the error messages.
[savage@d0ol30 extensions]$ gmake
stat(): No such file or directory at ./config/fullPathName.pl line 6
gmake -C configure buildInstall
gmake[1]: Entering directory `/mnt/nobackup/home/savage/extensions/configure'
gmake -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 buildInstall
gmake[2]: Entering directory `/mnt/nobackup/home/savage/extensions/configure/O.l
inux-x86'
gmake[2]: Nothing to be done for `buildInstall'.
gmake[2]: Leaving directory `/mnt/nobackup/home/savage/extensions/configure/O.li
nux-x86'
gmake[1]: Leaving directory `/mnt/nobackup/home/savage/extensions/configure'
gmake -C src buildInstall
stat(): No such file or directory at ../config/fullPathName.pl line 6
gmake[1]: Entering directory `/mnt/nobackup/home/savage/extensions/src'
gmake -C alh buildInstall
stat(): No such file or directory at ../../config/fullPathName.pl line 6
gmake[2]: Entering directory `/mnt/nobackup/home/savage/extensions/src/alh'
perl /d0usr/products/epics/NULL/base-3.14.5/bin/linux-x86/makeMakefile.pl O.linu
x-x86 Host
Can't open perl script "/d0usr/products/epics/NULL/base-3.14.5/bin/linux-x86/mak
eMakefile.pl": No such file or directory
gmake[2]: *** [O.linux-x86] Error 2
gmake[2]: Leaving directory `/mnt/nobackup/home/savage/extensions/src/alh'
gmake[1]: *** [alh.buildInstall] Error 2
gmake[1]: Leaving directory `/mnt/nobackup/home/savage/extensions/src'
gmake: *** [src.buildInstall] Error 2
[savage@d0ol30 extensions]$ printenv HOST_ARCH Linux
[savage@d0ol30 extensions]$ cat config/RELEASE
#RELEASE Location of external products
EPICS_EXTENSIONS=$(TOP)
#EPICS_BASE=/usr/local/iocapps/R3.13.9/support/base/3-13-9-asd1
#EPICS_BASE=/usr/local/iocapps/R3.14.5/support/base/3-14-5-asd1
EPICS_BASE=/d0usr/products/epics/NULL/base-3.14.5
The file ./config/fullPathName.pl does indeed exists in the extensions area. The makeMakefile.pl was not installed in the base-3.14.5 build. Any suggestions?
I'm going to try and use the makeBaseExt.pl script to create a new extensions area.
Thanks for the support.
Geoff
Re: building R3.13 extensions with R3.14.5 Andy Foster
Prev: Re: ANSI compilation error for ppc604 target. Andrew Johnson
Next: RTEMS BSP for MVME5500 Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: building R3.13 extensions with R3.14.5 Andy Foster
