1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM crashes immediately under Linux
To: [email protected]
Date: Tue, 18 May 2004 17:10:12 -0500
On Tue, May 18, 2004 at 04:40:57PM -0500, Robert Soliday wrote:
> Delete epics/base/bin/linux-x86/makeMakefile.pl and
> epics/base/bin/linux-x86/installEpics.pl
> Edit epics/base/configure/CONFIG_SITE and set:
> COMPAT_313=YES
> Next type make from epics/base to setup the the 3.13 compatibility. It
> shouldn't need to rebuild any of the programs in base.
> Now you should be able to build medm without worrying about the perl
> scripts.
> You could also download our Redhat RPM
> EpicsExtensions-3.14.5-1_3.2x.i386.rpm that contains medm.
> http://www.aps.anl.gov/asd/oag/installationGuide_Linux.htm
> --Bob Soliday
Great! This solved my problem. This made MEDM compile out of the box.
And it doesn't crash when I run it now.
Thanks for the fast and excellent help!
-lewis
> J. Lewis Muir wrote:
> > Hello. I'm having problems getting the EPICS MEDM extension to work.
> > medm crashes when I try to run it.
> > Below, I've stated exactly how I've built EPICS and the MEDM extension.
> > These steps were performed on an x86 Red Hat Enterprise Linux (RHEL) WS
> > v.3 computer. I have tried the same steps on an x86 Red Hat Linux 9
> > computer with the same results.
> > The version of gcc is 3.2.3.
> > The version of Open Motif is 2.2.2.
> > The version of XFree86 is 4.3.0.
> > Here are the steps I followed to build EPICS and the MEDM extension.
> > Download needed files:
> > $ cd /data/jlmuir
> > $ mkdir downloads
> > $ cd downloads
> > $ wget http://www.aps.anl.gov/epics/download/base/baseR3.14.5.tar.gz
> > $ wget http://www.aps.anl.gov/epics/download/extensions/\
> > extensionsConfig_20040406.tar.gz
> > $ wget http://www.aps.anl.gov/epics/download/extensions/medm3_0_3.tar.gz
> > $ cd ..
> > Build EPICS Base 3.14.5:
> > $ mkdir opt
> > $ mkdir opt/epics-3.14.5
> > $ cd opt/epics-3.14.5
> > $ tar -xzvf ../../downloads/baseR3.14.5.tar.gz
> > $ mv base-3.14.5/ base
> > $ cd base
> > $ export EPICS_HOST_ARCH=linux-x86
> > $ make clean uninstall
> > $ make
> > $ cd ..
> > Build EPICS MEDM extension:
> > (I've left out the new-style extensionsConfigure_20040406.tar.gz files
> > since MEDM doesn't seem to use them. I've also tried including them but
> > they don't make the crash problem go away.)
> > $ tar -xzvf ../../downloads/extensionsConfig_20040406.tar.gz
> > $ tar -xzvf ../../downloads/medm3_0_3.tar.gz
> > $ cd extensions
> > $ vi config/RELEASE
> > EPICS_BASE=/data/jlmuir/opt/epics-3.14.5/base
> > $ cd src/medm
> > (make fails without doing this first)
> > $ cp ../../../base/configure/tools/makeMakefile.pl \
> >   ../../../base/bin/linux-x86/
> > $ cp ../../../base/configure/tools/installEpics.pl \
> > $ make
> > This time it seems to mostly compile but fails when linking medm with a
> > bunch of undefined reference errors like this:
> > cc   medm.o   -o medm
> > medm.o(.text+0x26a): In function `parseCommandLine':
> > : undefined reference to `medmPrintf'
> > medm.o(.text+0x2d0): In function `parseCommandLine':
> > : undefined reference to `convertNameToFullPath'
> > medm.o(.text+0x45d): In function `parseCommandLine':
> > : undefined reference to `extractStringBetweenColons'
> > The command "cc medm.o -o medm" doesn't look right since it doesn't
> > include any of the libraries that medm needs.
> > So I compile it by hand like this:
> > $ cd medm/O.linux-x86
> > $ cc -o medm *.o -L/usr/X11R6/lib -lX11 -lXt -lXm -lm \
> >   -L/data/jlmuir/opt/epics-3.14.5/base/lib/linux-x86 -lca -lCom \
> >   ../../xc/O.linux-x86/libANLwidgets.a \
> >   ../../printUtils/O.linux-x86/libPrintUtils.a
> > Now I try to run it:
> > $ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/data/jlmuir/opt/\
> > $ ./medm
> > (The first two error messages repeat many times (and the first appears
> > more times than the second) and then it exits after the last error:)
> > Tue May 18 15:39:07 CDT 2004
> > xErrorHandler:
> > BadWindow (invalid Window parameter)
> > xtErrorHandler:
> > No realize class procedure defined
> > Tue May 18 15:39:08 CDT 2004
> > xtErrorHandler:
> > MEDM Version 3.0.3: Loading aliased fonts..
> > SIGSEGV
> > Aborted
> > Does anyone have any suggestions to help me get this working? I'd also
> > be interested in hearing whether anyone has gotten this version of EPICS
> > and MEDM to work on other systems (Linux or otherwise).
> > Thanks!
> > -lewis
MEDM crashes immediately under Linux J. Lewis Muir
Prev: MEDM crashes immediately under Linux J. Lewis Muir
Next: next 3.14 release Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
