Hi everyone,
I update EPICS base R3.13.3 to R3.13.9 on solaris7. Building base R3.13.9 is OK. But after I create an example application and use gmake to build, it occurs:
gmake[1]: Entering directory `/ssrf/project/epics313_app/test139/iocBoot'
gmake -C iocexample buildInstall
gmake[2]: Entering directory `/ssrf/project/epics313_app/test139/iocBoot/iocexample'
Usage: convertRelease.pl [-a arch] [-h hostarch] [-t top] outfile
where outfile is be one of:
checkRelease - checks consistency with support apps
cdCommands - generate cd path strings for IOC use
CONFIG_APP_INCLUDE - additional build variables
gmake[2]: *** [cdCommands] Error 2
gmake[2]: Leaving directory `/ssrf/project/epics313_app/test139/iocBoot/iocexample'
gmake[1]: *** [iocexample.buildInstall] Error 2
gmake[1]: Leaving directory `/ssrf/project/epics313_app/test139/iocBoot'
gmake: *** [iocBoot.buildInstall] Error 2
The <top>/config/RELEASE is :
# RELEASE - Location of external products
# (Architecture dependent declarations should go into RELEASE.<arch>)
# Note: This file will be scanned to automatically generate
# include path definitions etc.
# The order of the following declarations will be retained
# within those definitions.
# Add your declarations here
TEMPLATE_TOP=/ssrf/project/master/epics/R3.13.9/base/templates/makeBaseApp/top
#SHARE=
EPICS_BASE=/ssrf/project/master/epics/R3.13.9/base
Could somebody give me some suggestion? Thanks.
Lifang
Problems w/ VxWorks Global Variable Device Records Susanna Jacobson
Power Ten power supplies Deb Kerstiens
<2004>
2025
2026
EtherIP & AB PLC's D Wetherholt
<2004>
2025
2026
