1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time
To: [email protected]
Date: Wed, 02 Jun 2004 19:46:50 +0200
The behaviour of msi is sick, because the expanded .db file will depend of the order of the lines, the use of the expansion tool msi/dbLoadTemplate and, neither all writing errors nor forgotten strings will be recognised.
It would be more usefull to have default values for substitutions that may be overwritten in the string expansion lines. May be something like this:
file test.template {
pattern{ NAME, HOPR="9", LOPR="1", MDEL="0.1"}
{ "X", "7", "-1", "0.2"} --> this is the original idea of the pattern
{ "Y" } --> use the defaults
{ "X", LOPR="-1"} --> use the defaults, but not for LOPR
{ HOPR="5"} --> To forget the NAME (no default defined) should cause an error
regards
-- [email protected] ----------- Bessy Gmbh -----------------
-- +49 30 6392 4981 ------------------ Albert Einstein Strasse 15 -
-------------------------------------- 12489 Berlin ---------------
RE: found a bug in 3.13.9 dbLoadTemplate - after all that time Chestnut, Ronald P.
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Tim Mooney
Prev: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Tim Mooney
Next: organizing extensions/applications Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: found a bug in 3.13.9 dbLoadTemplate - after all that time J. Frederick Bartlett
