1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Initializing a record VAL field with a constant
Date: Fri, 11 Jun 2004 12:30:12 -0500
Mark,
  Yes, that works and, when a value is assigned to the VAL field via the
"field" directive in the database definition file, the UDF field is set to
zero just as it is when the INP field is used for initialization. Is there
any reason to use the INP (or OUT) field for initialization rather than
initializing the VAL field directly?
								Fritz
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, June 11, 2004 12:09 PM
> To: [email protected]
> Hi Fritz,
> Why not put the initial string (and ai) values directly into the
> VAL field, rather than using INP?  I know that works for
> stringout, and I assume it should work for stringin as well.
> Mark Rivers
> From:	J. Frederick Bartlett [mailto:[email protected]]
> Sent:	Fri 6/11/2004 11:57 AM
> To:	tech-talk
> Cc:	Bartlett, Fritz
> Subject:	Initializing a record VAL field with a constant
>   Recently I was adding some new records to our name/value server
> IOC and I
> noticed an unexpected behavior. My new records, which are of type
> longin and
> ai, are used to supply system-wide values, i.e. firmware version
> numbers for
> comparison with hardware, computational constants, etc., for the
> rest of the
> control system. The records are initialized by placing a constant value in
> the INP field of the record definition text.
>   As one would expect, after initialization the UDF field for
> these records
> is zero, indicating that the VAL field has had a value assigned at some
> point in the record's existence. What I did not expect was that the SEVR
> field is set to INVALID and the STAT field to UDF. I would have expected
> that, if you are going to bother to set the UDF field to zero, consistency
> would dictate that the SEVR and STAT fields would be given the value
> NO_ALARM, just as it would be when the VAL field is set by a CA put
> operation. Is this behavior intentional and, if so, why?
>   I also discovered that, for the stringin record, this technique
> of setting
> an initial value by placing a constant -- in this case a string
> constant --
> in the INP field does not work at all. Is there a corresponding method for
> initializing the VAL field of a stringin record?
>   By the way, we are still using version 3.13.4.
> 								Fritz
Prev: Initializing a record VAL field with a constant J. Frederick Bartlett
Next: Re: Initializing a record VAL field with a constant Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Initializing a record VAL field with a constant Andrew Johnson
Next: RE: Initializing a record VAL field with a constant Allison, Stephanie
