1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PREC
To: TECHTALK <[email protected]>
Date: Fri, 11 Jun 2004 13:14:54 -0500
At 09:49 AM 6/11/2004 -0700, Allison, Stephanie wrote:
Here is a radical thought - it would be nice to have a new string field (ie, .FMT) that specifies how to display the value as a string. Then I could set up the format of our vacuums (ie, VALs that should always be displayed using exponential notation) in the database instead of having to override the default display format in each client. Also, some save/restore tools won't restore the proper values of things like vacuum limits unless you set a ridiculously large PREC.
Nice idea. But someone can always come up with a standard situation where a single format specifier for all fields is problematic. How can we handle some fields differently from others?
For instance, using the "motor" record, the MRES field
has the distance (in EGU) that the motor takes with each
integer step pulse.  Users always want the motor VAL and
RBV fields to be displayed in a %f format.  BUT, MRES can
have significant figures which, by its very definition,
extend well past what a PREC field will show.  If the PREC
field is used to format an archive of the MRES field with
a %f format specifier, such as with caGet and camonitor,
there will be a loss of precision due to truncation.
With the motor record, there is a work around for this,
store the SREV and UREV fields, which are used to compute
MRES.  UREV can be represented with the standard format
and SREV is an integer.  (MRES = UREV / SREV)
See this short example to illustrate this situation:
jemian,3$  camonitor iad:m58:c0:m1.{MRES,SREV,UREV}
 iad:m58:c0:m1.MRES             06/11/04 12:59:58.405796463 0.00000
 iad:m58:c0:m1.SREV             06/11/04 12:59:58.405796463  50800
 iad:m58:c0:m1.UREV             06/11/04 12:59:58.405796463 0.13022
jemian,4$ caget iad:m58:c0:m1.MRES
iad:m58:c0:m1.MRES             2.56339e-06
jemian,5$ caget iad:m58:c0:m1.SREV
iad:m58:c0:m1.SREV             50800
jemian,6$ caget iad:m58:c0:m1.UREV
iad:m58:c0:m1.UREV             0.13022
jemian,7$ caget iad:m58:c0:m1.PREC
iad:m58:c0:m1.PREC             5
jemian,8$ caget iad:m58:c0:m1.VAL
iad:m58:c0:m1.VAL              10.7464
jemian,9$ caget iad:m58:c0:m1.RBV
iad:m58:c0:m1.RBV              10.7464
jemian,10$ echo iad:m58:c0:m1.{MRES,SREV,UREV,PREC,VAL,RBV}\\n | caGet
iad:m58:c0:m1.MRES              0.00000
iad:m58:c0:m1.VAL               10.74640
iad:m58:c0:m1.RBV               10.74640
 *** caGet completed normally ***
Pete Jemian
Re: PREC Andrew Johnson
Prev: Re: PREC Brian McAllister
Next: Re: Initializing a record VAL field with a constant Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PREC Tim Mooney
Next: Re: PREC Andrew Johnson
