1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PREC
To: Brian McAllister <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Mon, 14 Jun 2004 09:19:21 +0200
Brian McAllister wrote:
Dirk Zimoch wrote:
> All tools including caget and camonitor should honor PREC.
Caget has command line arguments that can be used to specify both format
and precision.  I find that having a default precision rather than using
what's defined in the record is useful, as people frequently neglect to set
the precision and 0 is rarely useful for floating-point numbers.  I would
probably end up creating an alias specifying a format if it used PREC by
default.  Perhaps if one could distinguish between an explicit PREC=0 and
"no PREC defined" it would make sense to honor PREC by default, but that is
not currently possible.
To be lazy is not an excuse. If the PREC field is 0 it IS defined. And that people "forget" to set it is mainly because it is not used by the command line tools, I think.
The key word here (in the discussion) is "DISPLAY".  When a value is
retrieved as a number in native format, PREC correctly has no effect.  The
number is the number, and is not truncated or rounded.  How that number is
displayed should always be controllable by the client, with PREC (like
HOPR/LOPR) as a *suggestion* indicating what the database designer believes
is appropriate, which is used by default if the user doesn't specify
otherwise.
MEDM (and I assume the other display tools) allows the user to display
numbers is whatever format they please, including displaying the same value
in more than one format.  This is a GOOD THING.
You're right: "if the user doesn't specify otherwise". I do not want to forbid the user to specify an other precision. But if the user doesn't specify one, the precision provided by the record should be used. And caget DOES display the value, thus it should honor display parameters.
Allison, Stephanie wrote:
> Here is a radical thought - it would be nice to have a new string field > (ie, .FMT) that specifies how to display the value as a string. Then I > could set up the format of our vacuums (ie, VALs that should always be > displayed using exponential notation) in the database instead of having > to override the default display format in each client. Also, some > save/restore tools won't restore the proper values of things like > vacuum limits unless you set a ridiculously large PREC.
Vacuum readouts are what I had in mind when looking for a way to specify exponential format. The advantge of implementing that with negative PREC values is that no additional field is needed and, as Andrew pointed out, a format string requires a change in CA, but negative PREC values don't.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
Re: PREC Brian McAllister
Prev: Re: RDB connection from IOC [was:] Noboru Yamamoto
Next: Hytec drivers & PSI CVS Korhonen Timo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PREC Brian McAllister
Next: RE: PREC Allison, Stephanie
