1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: how to install a new sequencer program
To: [email protected]
Date: Thu, 17 Jun 2004 10:39:54 +0200
Hello,
please let me ask a question of a beginner. I tryed the example applications of baseR3.14.6 on SUSE linux 9.0. Everythink works well. Now I tryed to change the name of the Sequencer program to find out, how I can install my own program. For this I did the following:
coppy "sncExample.stt" to "sncProgram2.stt" and change the first line to:
program sncProgram2
changed the "Makefile" in exampleApp/src/    to:
ifneq ($(SNCSEQ),)
   # This builds sncExample as a component of example
#    example_DBD += sncExample.dbd
#    example_SRCS += sncExample.stt
#    example_LIBS += seq pv
   # The following builds sncProgram as a standalone application
   PROD_HOST += sncProgram2
   sncProgram_SNCFLAGS += +m
   sncProgram_SRCS += sncProgram2.stt
   sncProgram_LIBS += seq pv
   sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
changed the last line of "st.cmd" to: seq sncProgram2,"user=wehlerHost"
running "make" I get the following error message:
/home/wehler/EPICS3/SEQ/seq-2.0.8/bin/linux-x86/snc .../sncProgram2.stt -o sncProgram2.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/wehler/EPICS3/SEQ/seq-2.0.8/include/os/Linux -I/home/wehler/EPICS3/SEQ/seq-2.0.8/include -I/home/wehler/EPICS3/base-3.14.6/include/os/Linux -I/home/wehler/EPICS3/base-3.14.6/include sncProgram2.c
/usr/bin/g++ -o sncProgram2 -Wl,-rpath,/home/wehler/EPICS3/TOP_SEQ3a/lib/linux-x86 -Wl,-rpath,/home/wehler/EPICS3/SEQ/seq-2.0.8/lib/linux-x86 -Wl,-rpath,/home/wehler/EPICS3/base-3.14.6/lib/linux-x86 sncProgram2.o
/usr/lib/gcc-lib/i586-suse-linux/3.3.1/../../../crt1.o(.text+0x18): In function `_start':
.../sysdeps/i386/elf/start.S:98: undefined reference to `main'
sncProgram2.o(.text+0x6): In function `sncProgram2Registrar':
: undefined reference to `seqRegisterSequencerCommands'
sncProgram2.o(.text+0x13): In function `sncProgram2Registrar':
: undefined reference to `seqRegisterSequencerProgram'
sncProgram2.o(.text+0x46): In function `D_ss1_low':
: undefined reference to `seq_delayInit'
sncProgram2.o(.text+0x99): In function `E_ss1_low':
: undefined reference to `seq_delay'
sncProgram2.o(.text+0xf6): In function `D_ss1_high':
sncProgram2.o(.text+0x149): In function `E_ss1_high':
collect2: ld returned 1 exit status
make[3]: *** [sncProgram2] error 1
make[3]: Leaving directory `/home/wehler/EPICS3/TOP_SEQ3a/exampleApp/src/O.linux-x86'
make[2]: *** [install.linux-x86] error 2
make[2]: Leaving directory `/home/wehler/EPICS3/TOP_SEQ3a/exampleApp/src'
make[1]: *** [src.install] error 2
make[1]: Leaving directory `/home/wehler/EPICS3/TOP_SEQ3a/exampleApp'
make: *** [exampleApp.install] error 2
The same message arises when I build the directory structure with
..../makeBaseApp.pl -t caClient caClient
Can someone explain me what I did wrong?
Thanks in advance
Dorothea Wehler
Dr. Dorothea Wehler
Cryoelectra GmbH
Linde 72-74
D-42287 Wuppertal, Germany
Tel: +49 202 / 69824-17
Fax: +49 202 / 69824-40
Re: how to install a new sequencer program Marty Kraimer
Re: how to install a new sequencer program Andrew Johnson
Prev: Re: Initializing a record VAL field with a constant Andrew Johnson
Next: Re: how to install a new sequencer program Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Hytec drivers & PSI CVS Korhonen Timo
