I'm trying to build the new gateway version 2.0.0.0.Beta8 on SuSE-Linux and got a bit confused. The downloaded base 3.14.6 is quickly built after a minor change in one config file. I've got problems to build the gnuRegex and the gateway extensions pack. These two cannot be built because of missing old 3.13 style config files on the extensions tree. My confusion is being caused by using still the old 3.13 config files for an application that needs exclusive the 3.14 base. I'd like to prepare a road-map how to build the gateway and I need more information for that. Can somebody explain me, why we still need the old 3.13 config files to build the gnuRegex and the gateway version 2.x ? If it's absolute necessarily to build with the 3.13 configs, what are the simplest steps ? Regards, Zoltan -- Zoltan Kakucs Deutsches Elektronen-Synchrotron DESY in der Helmholtz-Gemeinschaft Cryogenic Control Group Notkestraße 85 D-22607 Hamburg +49 (0) 40 8998 - 3283 Voice +49 (0) 40 8998 - 4388 Fax mailto: [email protected] DESY Hamburg at http://www.desy.de ********************************************* "Nicht Sprueche sind es, woran es fehlt; die Buecher sind voll davon. Woran es fehlt, sind Menschen, die sie anwenden." Epiktet *********************************************
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
