1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: caSnooper output report question
To: "tech-talk (E-mail)" <[email protected]>
Date: Thu, 24 Jun 2004 14:18:40 -1000
I've built caSnooper under R3.14.6 for solaris-sparc-gnu host.
I have a couple of questions regarding the output report between the GUI and
command line.
Below are 3 number output reports.  The first and third reports were
generated from the CaSnooper MEDM GUI via the report button with:
	Check Top N:        = 10
	Print Top N:        = 10
	Print Over N-Sigma: = -1
	Print Over Hz:      = -1
The second report is from the command line.
My questions are:
- Why does the MEDM report output not have the "PP", "CPP" PVs until after
I've run the command line report?  I've verified this multiple times by
stopping are restarting caSnooper and the GUIs but not the IOCs (EPICS
R3.13.0Beta12) so the broadcasts are always there.
- Why are the rates between the two report generation types different?
Report 2 "PP" = 46hz, report 3 "PP" = 5hz.
- Finally what is the "request rate" on the GUIs really telling me?
Thank you in advance.
Kevin
1) From CaSnooper xterm launched from runCaSnooper report button:
Jun 24 12:58:08:
There were 1099 requests to check for PV existence for 247 different PVs.
  Max(Hz):   0.63
  Mean(Hz):  0.08
  StDev(Hz): 0.14
PVs with top 10 requests:
   1 kepuhi:34211                   k1:dcs:dom:bsRaiseOut             0.63
   2 kepuhi:34211                   k1:dcs:dom:tsPosition             0.59
   3 kepuhi:34211                   k1:dcs:dom:tsLowerOut             0.59
   4 kepuhi:34211                   k1:dcs:dom:tsRaiseOut             0.59
   5 kepuhi:34211                   k1:dcs:dom:bsLowerOut             0.58
   6 kepuhi:34211                   k1:dcs:dom:bsPosition             0.58
   7 kepuhi:32985                   k0:met:humidityRaw                0.54
   8 kepuhi:40783                   CaSnoop.DESC                      0.47
   9 kepuhi:32985                   k0:met:tempRaw                    0.40
  10 kepuhi:32985                   k0:met:GEUnitInvalram             0.38
Connection status for top 10 PVs after 10.00 sec:
   1 kepuhi:34211                   k1:dcs:dom:bsRaiseOut             C
0.63
   2 kepuhi:34211                   k1:dcs:dom:tsPosition             C
0.59
   3 kepuhi:34211                   k1:dcs:dom:tsLowerOut             C
0.59
   4 kepuhi:34211                   k1:dcs:dom:tsRaiseOut             C
0.59
   5 kepuhi:34211                   k1:dcs:dom:bsLowerOut             C
0.58
   6 kepuhi:34211                   k1:dcs:dom:bsPosition             C
0.58
   7 kepuhi:32985                   k0:met:humidityRaw                C
0.54
   8 kepuhi:40783                   CaSnoop.DESC                      NC
0.47
   9 kepuhi:32985                   k0:met:tempRaw                    C
0.40
  10 kepuhi:32985                   k0:met:GEUnitInvalram             C
0.38
2) From command line:
k1server{k1obs}%
/usr/local/epics/r3.14.6/extensions/bin/solaris-sparc-gnu/caSnooper -t10
-c10 -p10
Starting CaSnooper 2.1.0.1 (8-27--2003) at Jun 24 12:58:35
EPICS 3.14.6
Individual Name is CaSnoop.test
Internal PV names are not being published
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 38566,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
CaSnooper terminating after 10.02 seconds [0.17 minutes]
  Data collected for 10.02 seconds [0.17 minutes]
Jun 24 12:58:45:
There were 4849 requests to check for PV existence for 222 different PVs.
  Max(Hz):   46.02
  Mean(Hz):  2.18
  StDev(Hz): 4.71
   1 aocpu1:1026                    PP                                46.02
   2 aocpu1:1026                    CPP                               37.93
   3 aocpu1:1026                    k1:ao:sc:ob:acam:acam:            20.06
   4 aocpu2:1026                    k1:ao:dmState                     6.59
   5 aocpu1:1026                    k1:ao:wc:tl:utErrVec              4.19
   6 kepuhi:32882                   k1:dcs:sec:sonyG5Value            3.89
   7 kepuhi:32882                   k1:dcs:sec:sonyG2Value            3.89
   8 kepuhi:32882                   k1:dcs:sec:sonyG6Value            3.89
   9 kepuhi:32882                   k1:dcs:sec:sonyG4Value            3.89
  10 kepuhi:32882                   k1:dcs:sec:sonyG1Value            3.89
   1 aocpu1:1026                    PP                                NC
46.02
   2 aocpu1:1026                    CPP                               NC
37.93
   3 aocpu1:1026                    k1:ao:sc:ob:acam:acam:            NC
20.06
   4 aocpu2:1026                    k1:ao:dmState                     NC
6.59
   5 aocpu1:1026                    k1:ao:wc:tl:utErrVec              NC
4.19
   6 kepuhi:32882                   k1:dcs:sec:sonyG5Value            NC
3.89
   7 kepuhi:32882                   k1:dcs:sec:sonyG2Value            NC
3.89
   8 kepuhi:32882                   k1:dcs:sec:sonyG6Value            NC
3.89
   9 kepuhi:32882                   k1:dcs:sec:sonyG4Value            NC
3.89
  10 kepuhi:32882                   k1:dcs:sec:sonyG1Value            NC
3.89
k1server{k1obs}%
3) From CaSnooper xterm launched from runCaSnooper report button:
Jun 24 12:58:59:
There were 7473 requests to check for PV existence for 496 different PVs.
  Max(Hz):   5.04
  Mean(Hz):  0.14
  StDev(Hz): 0.37
   1 aocpu1:1026                    PP                                5.04
   2 aocpu1:1026                    CPP                               4.15
   3 aocpu1:1026                    k1:ao:sc:ob:acam:acam:            2.19
   4 aocpu2:1026                    k1:ao:dmState                     0.73
   5 kepuhi:34211                   k1:dcs:dom:bsRaiseOut             0.60
   6 kepuhi:34211                   k1:dcs:dom:tsRaiseOut             0.60
   7 kepuhi:34211                   k1:dcs:dom:tsPosition             0.59
   8 kepuhi:34211                   k1:dcs:dom:tsLowerOut             0.59
   9 kepuhi:34211                   k1:dcs:dom:bsPosition             0.57
  10 kepuhi:34211                   k1:dcs:dom:bsLowerOut             0.57
   1 aocpu1:1026                    PP                                NC
5.04
4.15
2.19
0.73
   5 kepuhi:34211                   k1:dcs:dom:bsRaiseOut             C
0.60
   6 kepuhi:34211                   k1:dcs:dom:tsRaiseOut             C
0.60
   7 kepuhi:34211                   k1:dcs:dom:tsPosition             C
0.59
   8 kepuhi:34211                   k1:dcs:dom:tsLowerOut             C
0.59
   9 kepuhi:34211                   k1:dcs:dom:bsPosition             C
0.57
  10 kepuhi:34211                   k1:dcs:dom:bsLowerOut             C
0.57
Re: caSnooper output report question Andrew Johnson
Prev: New labca release available Till Straumann
Next: Re: caSnooper output report question Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
