To be honest, I dont know if it's safe for a signal handler to join a
thread context. There's at least one possible race condition in this
case: the signal handler could execute after ca_task_exit() has been
called. What other race conditions are you thinking about?
I'm sure Jeff will weigh in when he gets back.
Chris Timossi
Eric Norum wrote:
Robert Soliday wrote:
Thanks, this solved my problem.
--Bob
Chris Timossi wrote:
Robert,
I believe that you should replace ca_task_initialize with
> ca_context_create(ca_enable_preemptive_callback) in main. Then in the
> interrupt handler, you can call ca_current_context() to get the
> current context and finally join that context with
> ca_attach_context().
Are you sure that this is safe? I suspect that calling these
functions from a signal handler is going to introduce all sorts of
race conditions.
Jeff -- can you confirm/deny my suspicions?
- Re: Proglem doing CA calls after catching a signal Eric Norum
- Proglem doing CA calls after catching a signal Robert Soliday
- Re: Proglem doing CA calls after catching a signal Robert Soliday
CGI Export wtw00992
<2004>
2025
2026
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
