Hello Kate,
Mr OH was added on what you attached Makefile.inc and mvme5500.cfg files.
Tried again to make utility after cleared before error messages, but the other error messages are
¡°compiled for a little endian system and target is big endian¡±.
Error Messqges:
File in wrong format: failed to merge target specific data of file /opt/rtems/lib/gcc-lib/pp
c-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(archive.o)
/opt/rtems/lib/gcc-lib/ppc-rtems/3.2.1/../../../../ppc-rtems/bin/ld: /opt/rtems/lib/gcc-lib/
ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(archures.o): compiled for a little endian
ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(bfd.o): compiled for a little endian syst
c-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(opncls.o)
ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(reloc.o): compiled for a little endian sy
He used patch files version are below:
binutils-2.13.2.1
gcc-3.2.1
rtems-ss-20030128
Did you used different of patch versions for MVME5500 target?
Sorry for much a question.
Kind regards,
Kiman.
PLS Control and taskforce team.
> -----Original message-----
> From: "KateFeng"
> To: [email protected]
> Cc: [email protected],[email protected]
> Date: 07/27/2004(Tue)02:33
> Subject: Re: RTEMSfor MVME5500
> [email protected] wrote:
> > Hello Kate,
> > >RTEMS-4.6.0 is better than RTEMS-4.6.0pre#. RTEMS-4.6.0 has
> > >PowerPC patches for RTEMS-4.6.0pre#.
> > He tried to recompile RTEMS-4.6.0 kernels and GeSys_2.1beta codes.
> > All passed before step what for build cexp : and xsyms :
> > >To build rtems5500-cexp.bin and rtems5500-cexp.sym :
> > >0) cd RTEMS5500-GeSys_2.1.beta
> > >1) make
> > Did you used bspcheck commands at Makefile line 142.
> Till Straumann wrote the original Makefile, which I added the
> support for the mvme5500. It appears to me bspcheck
> is not a command. Searching the Makefile, I got
> two lines regarding bspcheck.
> bspcheck: $(if $(filter $(RTEMS_BSP_FAMILY),pc386 mvme5500 motorola_powerpc
> svgm),,bspfail)
> and
> all: bspcheck libnms ${ARCH} $(SRCS) $(PGMS)
> > But when i type make commands after other error messages from Makefile line 142..
> > What is missing ?
> > root@rtemsdev RTEMS5500-GeSys_2.1.beta]# make
> > Makefile:142: *** GeSys has not been ported/tested on this BSP (mvme5500) yet.
> > Makefile: 142 Line :
> I could not duplicate your error message. What message did you
> get before those error message came out ?
> Make sure you have environment variable :
> RTEMS_MAKEFILE_PATH=/opt/rtems/ppc-rtems/mvme5500
> However, I do find out that you are missing
> /opt/rtems/make/custom/mvme5500.cfg (attached).
> Also, one has to modify the RTEMS5500-GeSys_2.1.beta/config
> files (e.g. libbfd.excl, libiberty.excl, and libopcodes.excl)
> to change the path from /opt/rtems3 to its own defined directory.
> The same as the ppc-rtems/mvme5500/Makefile.inc file.
> Regards,
> Kate
- Re: RTEMSfor MVME5500 Kate Feng
RE: Base on windows Mark Rivers
<2004>
2025
2026
<2004>
2025
2026
