Thanks to everyone who replied. I was using 3.14.4 - but on 3.14.6 with
cygwin, base built without problems as reported.
On Tue, 2004-07-27 at 16:55, Janet Anderson wrote:
> Steven Hunt wrote:
> > Does anyone have the configs to build base 3.14.x on windows running
> > cygwin/gcc ?
> > Steve Hunt
> The cygwin config files already exist in R3.14 base. You should be able to
> build R3.14.6 base and EPICS extensions after executing the following cygwin.bat
> file (with local changes made). If you have an earlier version of R3.14
> base change the EPICS_HOST_ARCH value from cygwin-x86 to win32-x86-cygwin.
> REM
> REM --------------- WINDOWS ---------------------------
> REM ----- WIN95 -----
> REM set PATH=C:\WINDOWS;C:\WINDOWS\COMMAND
> REM ----- WINNT -----
> set PATH=C:\WINNT;C:\WINNT\SYSTEM32
> REM --------------- GNU make (use cygwin make ) ----------------
> REM cygwin contains tk/tcl, vim, perl, and many unix tools
> set PATH=%PATH%;c:\cygwin\bin
> REM --------------- EPICS -----------------------------
> REM R3.14 requirements
> set EPICS_HOST_ARCH=cygwin-x86
> set PATH=%PATH%;G:\epics\base_R3_14\bin\%EPICS_HOST_ARCH%
> set PATH=%PATH%;G:\epics\extensions\bin\%EPICS_HOST_ARCH%
> REM ---------------- EPICS tools ----------------------
> REM HOST_ARCH needed for Makefile.Host builds
> set HOST_ARCH=cygwin32
- RE: Base on windows Jeff Hill
- Base on windows Steven Hunt
Re: Base on windows guobao shen
<2004>
2025
2026
<2004>
2025
2026
