1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA Gateway problem
To: TECHTALK <[email protected]>
Date: Thu, 05 Aug 2004 14:06:54 +0200
I'm using CA gateway 2.0.0.0Beta8 compiled with R3.14.6 to read records from another subnet. Now I found that one enum has the wrong value though the gateway. It is a bi with the two states "OK" and "ERROR". The record was on ERROR for weeks, but when it changed to OK, I could not see the change through the gateway! The severity however is correct, it went from MAJOR to NO_ALARM. All other records on the same IOC seem to be OK. I have checkes that there is no second record with the same name. What's wrong?
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
Prev: Re: How to pass constant string into a genSub or sub record Peregrine McGehee
Next: RE: CA Gateway problem Lahey, Terri E.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
