1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Gateway problem
To: "Tech-Talk" <[email protected]>
Cc: "Jeff Hill" <[email protected]>
Date: Fri, 6 Aug 2004 12:23:56 -0500
We have had problems of that nature that derive from a bug in RSRV, the
server in the IOCs, for 3.13 IOCs.  The IOC loses contact with the client
(e.g. Gateway) and marks the circuit as down but doesn't close the socket.
The Gateway thinks it is still connected and continues sending out its
cached data.  There is no way to make the Gateway reconnect except to
restart it.  All channels in the circuit are affected.  (A circuit is all
the connections between one client and one server, all associated with the
same TCP/IP socket.)  Other Gateway circuits are OK.  The problem seems to
be associated with a lack of MBUFs in the IOC at some time.  There may be no
memory problems later when you look at it, however.  This problem was fixed
in 3.13.10, and RSRV now closes the socket so that the Gateway knows it is
disconnected.
	-Ken
RE: CA Gateway problem Jeff Hill
Re: CA Gateway problem Dirk Zimoch
Prev: Re: CA Gateway problem Dirk Zimoch
Next: RE: CA Gateway problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
