1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Industry Pack support under RTEMS available?
Cc: Dorothea Wehler <[email protected]>, EPICS TechTalk <[email protected]>, "Allison, Stephanie" <[email protected]>
Date: Tue, 17 Aug 2004 12:08:40 -0400
Mark Rivers wrote:
> Hi Dorothea,
> > may I ask once again for drivers: Is someone using  carrier boards on
> > VME-systems running RTEMS together with  A/D- and D/A-converter
> > Industry Packs?
> > We  would like to install Industry Packs with 16bit A/D and D/A
> > converters respectively with a throuput of >=100kHz. We shortlist the
> > IP235 from Acromag, A/Dconverter and the IP-ADC-8401 from Hytec.
> I have a driver for the Acromag IP330 A/D, which is 16-bits.  I also
> have a driver for the Systran DAC-128V D/A, which is 12 bits.  Both of
> these are Industry Pack devices.  The drivers have been extensively
> rewritten in the last few weeks to use with the new "asyn" package that
> Marty Kraimer mentioned.
> The required packages are "IPAC", "asyn", and my drivers.  IPAC is
> maintained by Andrew Johnson.  I don't know if it has been tested under
> RTEMS.  I doubt if anyone is using my drivers under RTEMS yet, and I
> would guess that there will be a small amount of work required to get it
> all running on RTEMS.
I came across  some of 3.14.x compatible drivers lately, and  found most
of them  RTEMS ready (e.g. using epicsThreadSleep() instead of
taskDelay()).   I recalled  SPEAR3/SLAC had some  IPAC and  Hytec drivers
running  on RTEMS.   Maybe Stephanie  Allison knows where  is the
web download site.
Cheers,
Kate
RE: Industry Pack support under RTEMS available? Mark Rivers
Prev: RE: Industry Pack support under RTEMS available? Mark Rivers
Next: RE: Industry Pack support under RTEMS available? Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
