1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Industry Pack support under RTEMS available?
To: Kate Feng <[email protected]>
Cc: "Allison, Stephanie" <[email protected]>, "'Dorothea Wehler'" <[email protected]>, EPICS TechTalk <[email protected]>
Date: Tue, 17 Aug 2004 13:04:14 -0500
Sorry but I am not the person to resolve the problem since I do not currently have an RTEMS test environment.
I will say that what we name devLib should probably have been called devVMELib or something like that.
I will guess that trying to extend devLib to other buses, e.g. PCI will be a mistake. Thus it should only support VME.
Note that src/libCom/osi/os/RTEMS/devLibOSD.c is only 324 lines of code so making this work on powerPC architectures other than mpc750 should not be very difficult. It currently has the statement:
#if defined(__PPC__) && defined(mpc750)
around all the code.
Perhaps Till Straumann can comment?
Marty Kraimer
Kate Feng wrote:
"Allison, Stephanie" wrote:
The support assumes that you have developed a base/src/libCom/osi/os/RTEMS/devLibOSD.c for your target. The devLibOSD.c that is delivered with base 3.14.6 only supports PPC mpc750. There's been discussion offline of tech-talk about the best way to have a more generic RTEMS devLib but I don't think that discussion came to any conclusion.
The devLibOSD.c works for the RTEMS-mvme5500 and RTEMS-mvme2307 as well. I thought the discussion is a bus dependent issue (e.g. VME v.s. PC ). However, Marty can explain the detail better than me.
Regards, Kate
Re: Industry Pack support under RTEMS available? Kate Feng
RE: Industry Pack support under RTEMS available? Allison, Stephanie
Prev: Re: Industry Pack support under RTEMS available? Kate Feng
Next: EPICS Hardware Support web page suggestion Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Industry Pack support under RTEMS available? Kate Feng
