1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Ethernet/IP & ControlLogix
To: "Hammonds, John P." <[email protected]>, <[email protected]>
Date: Wed, 25 Aug 2004 06:59:22 -0600
Hi JOhn,
The reason it is going back to 1 - is that the driver reads the output and reflects that value in the database. This is done as there may be a different master for the outputs - like a Allen-BRadley PanelMate.
For outputs, it is a good idea to have the IOC write to a boolean that is a request to drive an output. Make the output momentary by setting the HIGH field. Have it write to a soft variable in the PLC. Then the PLC can compute any interlock logic necessary to determine if it is safe to write the output.
Kay will have to say more about why the output may not be changing.
Bob
On Tue, 24 Aug 2004 20:54:21 -0500
 "Hammonds, John P." <[email protected]> wrote:
We are starting to examine the use of ControlLogix PLCs at IPNS and I am
looking at Kay's driver for Ethernet/IP. We now have our first test
setup going and we are looking at some of the subtleties with how to
access various types of tags. I am very novice with any PLC so please
forgive my awkward use of terminology.
It appears that the only tags that are accessible to the EPICS driver
are ones provided at the controller level ( in RSLogix 5000 App). Is
this correct?
We have been able to access inputs (ai & bi) OK but have been having
some trouble with binary outs. So far we have avoided arrays
altogether. We have a binary out module ( relay out I believe ). We
can control an output of this directly using the base tag
Local:2:O.Data[3] with a binary output record. However, when we create
another tag which aliases Local:2:O.Data[3] and point the record at
this, we can turn the output on but cannot turn it off. I have an EPICS
screen that allows me to change the value and monitor the RVAL field.
Here I see the new value (0) temporarily reflected in the RVAL &VAL
fields but then it goes back to 1. No change is seen in RSLogix 5000.
We can reset the Value with RSLogix 5000 and repeat the process. The
same effect is seen for any "soft" tag. BTW the soft records that I
have are type BOOL.
Any ideas?
John Hammonds
Data Acquisition Systems Manager
Intense Pulsed Neutron Source
[email protected]
(630)252-5317
Bob Dalesio [email protected] 410 557 0297 Maryland 505 699 1632 Cell Phone
Re: EPICS Ethernet/IP & ControlLogix Kay-Uwe Kasemir
EPICS Ethernet/IP & ControlLogix Hammonds, John P.
Prev: EPICS Ethernet/IP & ControlLogix Hammonds, John P.
Next: Re: EPICS Ethernet/IP & ControlLogix Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
