I have another problem occuring when building the R3.14.6 sequencer/test/bad/misplacedExit.st I've listed the make output below, but what I find online 26 of the sequence misplaceExit.c is when(delay(.1)) Is there something that I could have setup incorrectly such this built-in sequence function no longer works or this a problem that only shows up in R3.14.6 when building on an hpux host? creek: .../test/bad > gmake gmake -C O.hpux-parisc -f ../Makefile TOP=../../.. T_A=hpux-parisc install gmake[1]: Entering directory `/tmp_mnt/net/csr/csr-home/luchini/work/epics/R3.14.6/support/seq/2-0/test/bad/O.hpux-parisc' cc -c -DOSITHREAD_USE_DEFAULT_STACK -DHP_UX -Aa -O +DAportable +z -D_HPUX_SOURCE -I. -I.. -I../../../include/os/hpux -I../../../include -I/home/guests/luchini/epics/R3.14.6/support/seq/2-0/include/os/hpux -I/home/guests/luchini/epics/R3.14.6/support/seq/2-0/include -I/home/guests/luchini/epics/R3.14.6/support/base/3-14-6-0/include/os/hpux -I/home/guests/luchini/epics/R3.14.6/support/base/3-14-6-0/include misplacedExit.c cc: "misplacedExit.c", line 1: warning 501: Empty source file. aCC -o misplacedExit -AA -mt -Wl,+b/home/guests/luchini/epics/R3.14.6/support/base/3-14-6-0/lib/hpux-parisc:/home/guests/luchini/epics/R3.14.6/support/seq/2-0/lib/hpux-parisc:/net/csr/csr-home/luchini/work/epics/R3.14.6/support/seq/2-0/lib/hpux-parisc,+s misplacedExit.o /usr/ccs/bin/ld: Unsatisfied symbols: main (Not referenced yet! Probably due to -u option) gmake[1]: *** [misplacedExit] Error 1 gmake[1]: Leaving directory `/tmp_mnt/net/csr/csr-home/luchini/work/epics/R3.14.6/support/seq/2-0/test/bad/O.hpux-parisc' gmake: *** [install.hpux-parisc] Error 2
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
